trouble with #include "_init.h"
Hello. I've just gotten started with Arduino and I have run into an odd problem. I put together a Danger Shield tonight and tried to load one of the example sketches for it. I received the following errors:
 \LOCALS~1\Temp\build20730.tmp\/_init.h: In function 'void ds_init()':
\LOCALS~1\Temp\build20730.tmp\/_init.h:31: error: 'INPUT' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:31: error: 'pinMode' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:36: error: 'OUTPUT' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:49: error: 'HIGH' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:49: error: 'digitalWrite' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:56: error: 'LOW' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:57: error: 'MSBFIRST' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:57: error: 'shiftOut' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:61: error: 'byte' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:61: error: expected `;'before 'i'
\LOCALS~1\Temp\build20730.tmp\/_init.h:61: error: 'i' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:64: error: 'delayMicroseconds' was not declared in this scope
\LOCALS~1\Temp\build20730.tmp\/_init.h:81: error: 'Serial' wasnot declared in this scope
 In function 'void loop()':
However, when I commented out the #include "_init.h" and pasted the contents of _init.h into the main sketch, I did not get the errors on compile. What might be causing this? Obviously the code works since it compiled properly as part of the sketch file. I am stumped as to what is causing the errors in the header file. Any help would be greatly appreciated.
What version of the software are you running?
It might also help if you can post the code :slight_smile:
I hadn't even thought of trying it on an older version. I got these errors with 12, but I installed 11 and it compiles fine. I don't think the code is the issue here. Is there a bug reporting page for the Arduino IDE?
If you have trouble with 0012 try 0011 and vice versa :slight_smile:
Try Software ? Bugs & Suggestions
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?board=swbugs
:slight_smile:
Ahh, I should have known. Thanks for your help.
No problem :slight_smile:
Good luck with your project :slight_smile:
Good day. I just got into this, and am having the same issue.
Didn't see anything in the bugs thread on this.
The question is: why is this happening? Another newbie (to Arduino) here, but a seasoned java programmer w/some c experience.
I don't wanna fall back to an older version of the compiler - i wanna fix the code from Zach...
I shall start probing around in the cpp and .h files - my initial inkling is that this is probably due to some changes made to the language/compiler having to do with prototypes/declarations?
One thing I see in the Arduino examples is keywords.txt - i don't see this in the danger shield examples...any thoughts?
I got the danger shield examples from sourceforge.
thanks, eric
Any
I think you just need to #include "WProgram.h" in _init.h. You might want to bug Zach to update his examples.
see http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1224864760/10#10 for a solution. Adding #include "WProgram.h" to the _init.h file fixes the issue when using 12. edit I see mellis beat me to referencing the answer he gave me before. You're awesome, mellis. Thanks for your help!
Strange, this seems to be a different problem and its not solved by including "WProgram.h" in _init.h (at least in the test I ran). The errors mentioned in the other thread were due to the casting macros. The errors posted here are due to missing prototypes.
#include "WProgram.h" in the sketch itself does fix this issue.
Just an fyi - for a quick fix, open _init.h (or any/all of your .h files), and copy the code from the .h file(s) into the .pde, then save, compile, upload to the board - works fine for me.
This must be a library path issue with 12. It sure would be nice to get a doc on this compiler exe.
Can we compile and upload to a board using Eclipse?
Thanks, Eric.
No need to copy the .h file contents. As per my previous post, just #include "WProgram.h" at the top of the sketch file
