Trouble with mini servo motor
I am fairly new to the world of Arduino and electronics. I am trying to control a mini servo with 2 pushbuttons, one to turn it left and one for right. I want the motor arm to increment/decrement by 10 degrees according to which button is pressed. The problem I am having is that the arm swings all the way to 0 or 180, rather than going by 10s. I tried to fix this several times in the code and I'm pretty sure I wired everything correctly. Code is posted below. Any help is greatly appreciated.
#include <Servo.h>  // servo library
Servo servo1;
const int buttonLPin = 2;
const int buttonRPin = 3;
int buttonLState;
int buttonRState;
const int ledPin = 13;
  servo1.attach(9);
  pinMode(buttonLPin, INPUT);
  pinMode(buttonRPin, INPUT);
  pinMode(13, OUTPUT);
  servo1.write(90);
  int position = servo1.read();
  int buttonLState;
  int buttonRState;
  buttonLState = digitalRead(buttonLPin);
  buttonRState = digitalRead(buttonRPin);
    if((buttonLState == LOW) && (buttonRState == HIGH))
      servo1.write(position + 10);
    if((buttonRState == LOW) && (buttonLState == HIGH))
      servo1.write(position - 10);
Please edit you post, and enclose you code with the "code"-tag.
You should know how to do this - You did read the first sticky-post in every forum, didn't you?
http://forum.arduino.cc/index.php?topic=148850.0
// Per.
It makes it much easier to follow code when it is properly presented in code tags.
The command servo.read() is really pointless - it doesn't get any info from the servo, it just uses data saved in the servo library. Your code would be much more transparent if you create a variable and save the position yourself whenever you send a command to change the servo position.
I suspect your problem is that loop() repeats thousands of times per second so a single press of the button appears to the Arduino as many presses. A crude solution would be to add delay(200);
after each servo.write(). This gives 200 milliseconds for you to take your finger off the button.
...R
It works fine now, thank you very much!
