Trouble with MPU6050 and odrive operation
Hi All
Has anyone here set up arduino +MPU6050+ odrive system? I’m using jrowberg library. I have the odrive supplying 5V to arduino and the mpu. After calibration, it will not enter closed loop state. The arduino then seems to freeze. Has anyone experienced this?
Below is the code I use:
#include <SoftwareSerial.h>
#include <ODriveArduino.h>
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
// for both classes must be in the include path of your project
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps_V6_12.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 mpu;
//MPU6050 mpu(0x69); // <-- use for AD0 high
// Printing with stream operator
template<class T> inline Print& operator <<(Print &obj,     T arg) { obj.print(arg);    return obj; }
template<>        inline Print& operator <<(Print &obj, float arg) { obj.print(arg, 4); return obj; }
// Serial to the ODrive
SoftwareSerial odrive_serial(19, 18); //RX (ODrive TX), TX (ODrive RX)
// Note: you must also connect GND on ODrive to GND on Arduino!
#define OUTPUT_READABLE_YAWPITCHROLL
// ODrive object
ODriveArduino odrive(odrive_serial);
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
bool blinkState = false;
// MPU control/status vars
bool dmpReady = false;  // set true if DMP init was successful
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 gy;         // [x, y, z]            gyro sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float euler[3];         // [psi, theta, phi]    Euler angle container
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
void dmpDataReady() {
  mpuInterrupt = true;
  // ODrive uses 115200 baud
  odrive_serial.begin(115200);
  Wire.begin();
  Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
  Fastwire::setup(400, true);
#endif
  // initialize serial communication
  // (115200 chosen because it is required for Teapot Demo output, but it's
  // really up to you depending on your project)
  while (!Serial); // wait for Leonardo enumeration, others continue immediately
  // initialize device
  Serial.println(F("Initializing I2C devices..."));
  mpu.initialize();
  pinMode(INTERRUPT_PIN, INPUT);
  // verify connection
  Serial.println(F("Testing device connections..."));
  Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
  // wait for ready
  Serial.println(F("\nSend any character to begin DMP programming and demo: "));
  while (Serial.available() && Serial.read()); // empty buffer
  while (!Serial.available());                 // wait for data
  while (Serial.available() && Serial.read()); // empty buffer again
  // load and configure the DMP
  Serial.println(F("Initializing DMP..."));
  devStatus = mpu.dmpInitialize();
  Serial.println("ODriveArduino");
  Serial.println("Setting parameters...");
  // In this example we set the same parameters to both motors.
  // You can of course set them different if you want.
  // See the documentation or play around in odrivetool to see the available parameters
  for (int axis = 0; axis < 2; ++axis) {
    odrive_serial << "w axis" << axis << ".controller.config.vel_limit " << 22000.0f << '\n';
    odrive_serial << "w axis" << axis << ".motor.config.current_lim " << 11.0f << '\n';
    // This ends up writing something like "w axis0.motor.config.current_lim 10.0\n"
  // supply your own gyro offsets here, scaled for min sensitivity
  mpu.setXGyroOffset(94);
  mpu.setYGyroOffset(-5);
  mpu.setZGyroOffset(-14);
  mpu.setXAccelOffset(-366);
  mpu.setYAccelOffset(-2184);
  mpu.setZAccelOffset(1528);
  // make sure it worked (returns 0 if so)
  if (devStatus == 0) {
    // Calibration Time: generate offsets and calibrate our MPU6050
    mpu.CalibrateAccel(6);
    mpu.CalibrateGyro(6);
    mpu.PrintActiveOffsets();
    // turn on the DMP, now that it's ready
    Serial.println(F("Enabling DMP..."));
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
    Serial.print(F("Enabling interrupt detection (Arduino external interrupt "));
    Serial.print(digitalPinToInterrupt(INTERRUPT_PIN));
    Serial.println(F(")..."));
    attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
    mpuIntStatus = mpu.getIntStatus();
    // set our DMP Ready flag so the main loop() function knows it's okay to use it
    Serial.println(F("DMP ready! Waiting for first interrupt..."));
    dmpReady = true;
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
    // ERROR!
    // 1 = initial memory load failed
    // 2 = DMP configuration updates failed
    // (if it's going to break, usually the code will be 1)
    Serial.print(F("DMP Initialization failed (code "));
    Serial.print(devStatus);
    Serial.println(F(")"));
  // configure LED for output
  pinMode(LED_PIN, OUTPUT);
  Serial.println("Ready!");
  Serial.println("Send the character '0' or '1' to calibrate respective motor (you must do this before you can command movement)");
  Serial.println("Send the character 's' to exectue test move");
  Serial.println("Send the character 'b' to read bus voltage");
  Serial.println("Send the character 'p' to read motor positions in a 10s loop");
  // if programming failed, don't try to do anything
  if (!dmpReady) return;
  // read a packet from FIFO
  if (mpu.dmpGetCurrentFIFOPacket(fifoBuffer)) { // Get the Latest packet
    #ifdef OUTPUT_READABLE_YAWPITCHROLL
        // display Euler angles in degrees
        mpu.dmpGetQuaternion(&q, fifoBuffer);
        mpu.dmpGetGravity(&gravity, &q);
        mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
//        Serial.print("ypr\t");
//        Serial.print(ypr[0] * 180 / M_PI);
//        Serial.print("\t");
//        Serial.print(ypr[1] * 180 / M_PI);
//        Serial.print(ypr[2] * 180 / M_PI);
//        Serial.println();
    #endif
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
  if (Serial.available()) {
    char c = Serial.read();
    // Run calibration sequence
    if (c == '0' || c == '1') {
      int motornum = c-'0';
      int requested_state;
      requested_state = ODriveArduino::AXIS_STATE_ENCODER_OFFSET_CALIBRATION;
      Serial << "Axis" << c << ": Requesting state " << requested_state << '\n';
      odrive.run_state(motornum, requested_state, true);
      delay(100);
      requested_state = ODriveArduino::AXIS_STATE_CLOSED_LOOP_CONTROL;
      odrive.run_state(motornum, requested_state, false); // don't wait
    if (c == '4') {//IDLE
      requested_state = ODriveArduino::AXIS_STATE_IDLE;
      odrive.run_state(R0_MOTOR, requested_state, false);
      odrive.run_state(L1_MOTOR, requested_state, false);
You should first play with MPU6050 alone as it's not that easy to interface. You need to first calibrate it to set its X Y Z axes and then test its example. Once you got your hands on it then interface Odrive with it.
Moreover, share link of your Arduino Library and also attach schematic to get idea of your circuit.
I already did that. Thanks for the suggestion. Any other ideas?
I'm creating a rocket that moves its fin based on the x and y axis because of a MPU. The electronics works so I have some expreince. I suggest powering servos with 6v and MPU with 5v pin and arduino with 9v.
Use this link to help you with code (the power from the circuit diagram didnt work for me... if you want to power servo from computer use 3v in and if you want to power it from a battery use 6v):
Hope this helpes (The link doens't cover the z axis which won't really matter for a car.
Here is the link to my repository: https://github.com/Jc7tee/MEGA_odrive.git
I managed to get the motors calibrated. All is well until I entered close loop control. After I leave the odrive in that state for some time, the arduino becomes unresponsive ( I send command through serial monitor). The odrive stuck in that state unless I manually turn off the power.
