Why use Ping.h? can't understand it, the basic code is so simple and for me works everytime.
Here's some code cut from one of my programs:
ong scanner(long cm)
const int pingPin=7, EchoPin=8;
long duration;
// The SRF005/HC-SR04 is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse before to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
pinMode(EchoPin, INPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
duration = pulseIn(EchoPin, HIGH);
delay(100);
// convert the time into a distance
// inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
return (cm);
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
void Radar()
Halt();
BackOff();
Lturn();
sound(2200,20);
Halt();
A=scanner(cm);
delay(100);
Rturn();
Rturn();
sound(2200,20);
Halt();
B=scanner(cm);
delay(100);
Lturn();
delay(50);
if (A>B)
Lturn(); //Then turn left
A=0;
Rturn(); //Then turn right
B = 0;
By the way the L329/L398 are poor drivers as you lose power (2v+) on the output transistors use something with FET outputs, more power... You have called the motors A & B that's fine so why not call the pins MA- MA+ makes sense!
Hope it helps, regards. (see www.melsaunders.co.uk for my bots)
Mel.
