I tried, double checked (triple-checked) all connections, and I'm unable to succeed with the "hello world" example.
I get only a "dark" first line. I tried to play with the example program, without any success. I do not think there are errors in the provided schematic, as, as far as I know, no one made a remark on the PICLIST pages.
I don't know if I am looking at the same page as you since your link is still broken. The page I am looking at shows a very strange pinout which may or may not be correct.
I would try connecting your device following the pin numbers 1 -14 as specified in the LiquidCrystal tutorial while ignoring the pin labels EN, DB0, etc on that PICLIST diagram.
floresta:
It is not a matter of "original LCD pins". This is a single assembly mounting the actual liquid crystal panel and the driver ICs. It performs the same function as the common displays available through various sellers, most notably eBay.
But it is an alternative form, not an adaptation. You should not think in terms of either form being "correct", it is just what it is and there is no "standard" for the pinout with which it is to be compared. Any given module generally has a pinout which reflects the pin sequence on the HD44780 chip and indeed the only variation here is the order of RS, R/W and EN.
