Trouble with RF24 library
Hello, I'm having trouble getting a simple RF24 program working. During compilation I keep getting all kind of error messages about missing or wrong statements in libraries NRF24 an/on nRF24L01. I've searched and read but have not come anywhere near a solution. I have attached the (extensive) error messages and the code. Any help will be greatly appreciated.`
(I hope the code and errors are readable.
/* This version 20220710
   feel free to copy (as I did many times)
   questions ? contact me !
    Ronald Ruijtenberg (ronald.ruytenberg@planet.nl)
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";     //Byte of array representing the address. This is the address where we will send the data. This should be same on the receiving side.
int button_pin = 2;
boolean button_state = 0;
  pinMode(button_pin, INPUT);
  radio.begin();                  //Starting the Wireless communication
  radio.openWritingPipe(address); //Setting the address where we will send the data
  radio.setPALevel(RF24_PA_MIN);  //You can set it as minimum or maximum depending on the distance between the transmitter and receiver.
  radio.stopListening();          //This sets the module as transmitter
  button_state = digitalRead(button_pin);
  if (button_state == HIGH)
    const char text[] = "Your Button State is HIGH";
    radio.write(&text, sizeof(text));                  //Sending the message to receiver
    const char text[] = "Your Button State is LOW";
  radio.write(&button_state, sizeof(button_state));  //Sending the message to receiver
Arduino:1.8.13 (Windows 10), Board:"Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Gebruiker\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Gebruiker\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Hobby\Arduino I\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Users\GEBRUI~1\AppData\Local\Temp\arduino_build_171537 -warnings=none -build-cache C:\Users\GEBRUI~1\AppData\Local\Temp\arduino_cache_78151 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Hobby\Arduino Master\NRF24\Sending_data_NRF24_20220710_1\Sending_data_NRF24_20220710_1.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Gebruiker\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Gebruiker\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Hobby\Arduino I\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Users\GEBRUI~1\AppData\Local\Temp\arduino_build_171537 -warnings=none -build-cache C:\Users\GEBRUI~1\AppData\Local\Temp\arduino_cache_78151 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Hobby\Arduino Master\NRF24\Sending_data_NRF24_20220710_1\Sending_data_NRF24_20220710_1.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for nRF24L01.h: [nRF24L01 NRFLite@3.0.3]
ResolveLibrary(nRF24L01.h)
  -> candidates: [nRF24L01 NRFLite@3.0.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Hobby\\Arduino I\\libraries\\nRF24L01" "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for RF24.h: [RF24]
ResolveLibrary(RF24.h)
  -> candidates: [RF24]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Hobby\\Arduino I\\libraries\\nRF24L01" "-IC:\\Hobby\\Arduino I\\libraries\\RF24" "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Hobby\\Arduino I\\libraries\\nRF24L01" "-IC:\\Hobby\\Arduino I\\libraries\\RF24" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src\\SPI.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Hobby\\Arduino I\\libraries\\nRF24L01" "-IC:\\Hobby\\Arduino I\\libraries\\RF24" "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp" -o "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Sketch aan het compileren...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Hobby\\Arduino I\\libraries\\nRF24L01" "-IC:\\Hobby\\Arduino I\\libraries\\RF24" "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp" -o "C:\\Users\\GEBRUI~1\\AppData\\Local\\Temp\\arduino_build_171537\\sketch\\Sending_data_NRF24_20220710_1.ino.cpp.o"
In file included from C:\Hobby\Arduino Master\NRF24\Sending_data_NRF24_20220710_1\Sending_data_NRF24_20220710_1.ino:9:0:
C:\Hobby\Arduino I\libraries\RF24/RF24.h:2:18: error: stray '\342' in program
 Search or jump to…
C:\Hobby\Arduino I\libraries\RF24/RF24.h:2:19: error: stray '\200' in program
 Search or jump to…
C:\Hobby\Arduino I\libraries\RF24/RF24.h:2:20: error: stray '\246' in program
 Search or jump to…
C:\Hobby\Arduino I\libraries\RF24/RF24.h:8:1: error: stray '@' in program
 @RonaldRuijtenberg
C:\Hobby\Arduino I\libraries\RF24/RF24.h:22:1: error: stray '@' in program
 @2bndy5
C:\Hobby\Arduino I\libraries\RF24/RF24.h:23:30: error: stray '#' in program
 2bndy5 Add isFifo() methods (#849)
C:\Hobby\Arduino I\libraries\RF24/RF24.h:24:1: error: stray '\342' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:24:2: error: stray '\200' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:24:3: error: stray '\246' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:1: error: stray '@' in program
 @TMRh20@maniacbug@2bndy5@gcopeland@Avamander@akatran@soligen2010@mz-fuzzy@komby@dstroy0@zador-blood-stained@wmarkow
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:8: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:18: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:25: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:35: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:45: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:53: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:65: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:74: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:80: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:88: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:28:108: error: stray '@' in program
C:\Hobby\Arduino I\libraries\RF24/RF24.h:1:1: error: 'Skip' does not name a type
 Skip to content
C:\Hobby\Arduino I\libraries\RF24/RF24.h:98:3: error: 'rf24_pa_dbm_e' does not name a type
 } rf24_pa_dbm_e;
C:\Hobby\Arduino I\libraries\RF24/RF24.h:1790:28: error: 'rf24_pa_dbm_e' has not been declared
     void startConstCarrier(rf24_pa_dbm_e level, uint8_t channel);
C:\Hobby\Arduino Master\NRF24\Sending_data_NRF24_20220710_1\Sending_data_NRF24_20220710_1.ino: In function 'void setup()':
Sending_data_NRF24_20220710_1:21:20: error: 'RF24_PA_MIN' was not declared in this scope
C:\Hobby\Arduino Master\NRF24\Sending_data_NRF24_20220710_1\Sending_data_NRF24_20220710_1.ino:21:20: note: suggested alternative: 'RF24_SPI_PTR'
                    RF24_SPI_PTR
Meerdere bibliotheken gevonden voor "nRF24L01.h"
Gebruikt: C:\Hobby\Arduino I\libraries\nRF24L01
Niet gebruikt: C:\Hobby\Arduino I\libraries\NRFLite
Bibliotheek SPI op versie 1.0 in map: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI  wordt gebruikt
Bibliotheek nRF24L01 in map: C:\Hobby\Arduino I\libraries\nRF24L01 (legacy) wordt gebruikt
Bibliotheek RF24 in map: C:\Hobby\Arduino I\libraries\RF24 (legacy) wordt gebruikt
exit status 1
Welcome to the forum
Please post the full sketches that you are having problems with, using code tags when you do, and also the full error messages copied from the IDE using the "Copy error message" button and put those in code tags too
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Hi RonaldRuijtenberg,
It looks like you have omitted the following Include within your sketch -
#include <RF24_config.h>
HTH?
Tried it but alas I keep getting a lot of this : 'error: stray '@' in program' and this :
and I haven't got a clue of where to resolve this. Thx for your swift reply though.
Do you have the latest version of the rf24 (TMR24) library installed?
Copy the code from your original post and compile it. I did and it compiles fine. The "stray" stuff is from your copying the code form a web page with embedded HTML. When you post the code in code tags that stray crap is removed by the forum software.
I tried but get the same errors. Where can I get the TMR24 library ? I tried Github but there it says : We couldn’t find any repositories matching 'TMR24'
This is the version that you should install. RF24 by TMR20
I just again tried copying the code from the original post into the IDE and it compiles with no warnings or errors.
I have just that :
![image|690x387](upload://wypqPkjsqlMEpknr4I5UvxgATMR.png)
but with a (major ?) difference : by you is says 'by TMRh20.Avamander version 1.4.3 INSTALLED.
By me it is only 'by TMRh20'
There is a button 'Install'
When I click that I get 'Library RF24 is already installed in: C:\Hobby\Arduino I\libraries\RF24'
I tried to make a printscreen but did not get it right.  Hope my text is clear enough.
I think I am one step further after installing the RF24.h from RF24-master.zip.
The 'only' error now is : ''pipe' was not declared in this scope'
Is this something that has to be declared in my code ?
Which sketch causes that error ?
The one in my initial post.
When I add this line directly under RF24 radio(9,10)
'const uint64_t pipe = 0xE8E8F0F0E1LL;'
I get 'undefined reference to `RF24::' for each statement in my code that begins with radio.
The code in your original code compiles OK for me with no changes
Then where is the difference ? The library or what ?
I suggest that you navigate to your Arduino sketchbook libraries folder
( ... \Documents\Arduino\libraries), find and delete the rf24 library that is there and then use the library manager to install the rf24 library by TMR20 (shown in the image in post #8.
Then you should have the latest version of the correct library correctly installed. I have copied and pasted the code from the OP into my IDE (version 1.8.19) and successfully compiled the code at least 4 times.
What version of the IDE are you using?
Let's compare the libraries
Do your RF24 examples look like this ?
If so, then open the RF24 GettingStarted example
With the sketch open select "Sketch/Show sketch folder" in the IDE
Navigate up the Windows file tree until you get to the RF24 folder and open the RF24.h file. The first line in mine is
Copyright (C) 2011 J. Coliz maniacbug@ymail.com
What is the first line of your RF24.h file ?
The first line(s) are :
Furthermore I have NO RF24 examples in Files/Examples.
I guess that I have a correct library but in the wrong place.
This did it !
The code compiled without errors !
I can start testing now.
Thanks a lot for helping me out !
Ronald Ruijtenberg
Cool. Have fun!
Have you got examples now ?
