i brought a rfid module (em-18) and some rfid cards( they dont have any company name printed on them )
when i first connect the reader to serial terminal i can see the data from the card
all the examples which i see in google have only 10digits in their rfid tag ,but i have 12 digits
the predefined rfid tags in the code has only 10 digits but my card has 12 digits
how to update the code so that it accepts my cards with 12 digits
my cards
6B0037E8398D
6B0037E158E5
6B003819CC86
0800692B5D17
* RFID Access Control Single
* This project implements a single stand-alone RFID access control
* system that can operate independently of a host computer or any
* other device. It uses either an ID-12 RFID reader module from ID
* Innovations or an RDM630 RFID reader module from Seeed Studio to
* scan for 125KHz RFID tags, and when a recognised tag is identified
* it toggles an output for a configurable duration, typically 2
* seconds. The output can then be used to control a relay to trip an
* electric striker plate to release a door lock.
* Because this project is intended to provide a minimal working system
* it does not have any provision for database updates to be managed
* externally from a host, so updates to the accepted cards must be
* made by changing the values in the code, recompiling the program,
* and re-uploading it to the Arduino. It does however report card
* readings (both successful and unsuccessful) via the serial
* connection so you can monitor the system using a connected computer.
* Some of this code was inspired by Tom Igoe's excellent RFID tutorial
* which is detailed on his blog at:
* http://www.tigoe.net/pcomp/code/category/PHP/347
* And also from the ID-12 example code on the Arduino Playground at:
* http://www.arduino.cc/playground/Code/ID12
* Copyright Jonathan Oxer <jon@oxer.com.au>
* http://www.practicalarduino.com/projects/medium/rfid-access-control
// Set up the serial connection to the RFID reader module. In order to
// keep the Arduino TX and RX pins free for communication with a host,
// the sketch uses the SoftwareSerial library to implement serial
// communications on other pins.
#include <SoftwareSerial.h>
// The RFID module's TX pin needs to be connected to the Arduino. Module
// RX doesn't need to be connected to anything since we won't send
// commands to it, but SoftwareSerial requires us to define a pin for
// TX anyway so you can either connect module RX to Arduino TX or just
// leave them disconnected.
// If you have built the circuit exactly as described in Practical
// Arduino, use pins D2 / D3:
#define rxPin 2
#define txPin 3
// If you are using the Freetronics RFID Lock Shield, use pins D4 / D5:
/* #define rxPin 4 */
/* #define txPin 5 */
// Create a software serial object for the connection to the RFID module
SoftwareSerial rfid = SoftwareSerial( rxPin, txPin );
// Set up outputs for the strike plate and status LEDs.
// Arduino, use pins D12 and D13:
#define strikePlate 12
#define ledPin 13
// If you are using the Freetronics RFID Lock Shield, use pins D6 / D7:
/* #define strikePlate 6 */
/* #define ledPin 7 */
// Specify how long the strike plate should be held open.
#define unlockSeconds 2
// The tag database consists of two parts. The first part is an array of
// tag values with each tag taking up 5 bytes. The second is a list of
// names with one name for each tag (ie: group of 5 bytes).
char* allowedTags[] = {
"0104F5B523", // Tag 1
"04146E8BDD", // Tag 2
"0413BBBF23", // Tag 3
// List of names to associate with the matching tag IDs
char* tagName[] = {
"Jonathan Oxer", // Tag 1
"Hugh Blemings", // Tag 2
"Dexter D Dog", // Tag 3
// Check the number of tags defined
int numberOfTags = sizeof(allowedTags)/sizeof(allowedTags[0]);
int incomingByte = 0; // To store incoming serial data
* Setup
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
pinMode(strikePlate, OUTPUT);
digitalWrite(strikePlate, LOW);
Serial.begin(38400); // Serial port for connection to host
rfid.begin(9600); // Serial port for connection to RFID module
Serial.println("RFID reader starting up");
* Loop
byte i = 0;
byte val = 0;
byte checksum = 0;
byte bytesRead = 0;
byte tempByte = 0;
byte tagBytes[6]; // "Unique" tags are only 5 bytes but we need an extra byte for the checksum
char tagValue[10];
// Read from the RFID module. Because this connection uses SoftwareSerial
// there is no equivalent to the Serial.available() function, so at this
// point the program blocks while waiting for a value from the module
if((val = rfid.read()) == 2) { // Check for header
bytesRead = 0;
while (bytesRead < 12) { // Read 10 digit code + 2 digit checksum
val = rfid.read();
// Append the first 10 bytes (0 to 9) to the raw tag value
if (bytesRead < 10)
tagValue[bytesRead] = val;
// Check if this is a header or stop byte before the 10 digit reading is complete
if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) {
break; // Stop reading
// Ascii/Hex conversion:
if ((val >= '0') && (val <= '9')) {
val = val - '0';
else if ((val >= 'A') && (val <= 'F')) {
val = 10 + val - 'A';
// Every two hex-digits, add a byte to the code:
if (bytesRead & 1 == 1) {
// Make space for this hex-digit by shifting the previous digit 4 bits to the left
tagBytes[bytesRead >> 1] = (val | (tempByte << 4));
if (bytesRead >> 1 != 5) { // If we're at the checksum byte,
checksum ^= tagBytes[bytesRead >> 1]; // Calculate the checksum... (XOR)
tempByte = val; // Store the first hex digit first
bytesRead++; // Ready to read next digit
// Send the result to the host connected via USB
if (bytesRead == 12) { // 12 digit read is complete
tagValue[10] = '\0'; // Null-terminate the string
Serial.print("Tag read: ");
for (i=0; i<5; i++) {
// Add a leading 0 to pad out values below 16
if (tagBytes[i] < 16) {
Serial.print("0");
Serial.print(tagBytes[i], HEX);
Serial.print("Checksum: ");
Serial.print(tagBytes[5], HEX);
Serial.println(tagBytes[5] == checksum ? " -- passed." : " -- error.");
// Show the raw tag value
//Serial.print("VALUE: ");
//Serial.println(tagValue);
// Search the tag database for this particular tag
int tagId = findTag( tagValue );
// Only fire the strike plate if this tag was found in the database
if( tagId > 0 )
Serial.print("Authorized tag ID ");
Serial.print(tagId);
Serial.print(": unlocking for ");
Serial.println(tagName[tagId - 1]); // Get the name for this tag from the database
unlock(); // Fire the strike plate to open the lock
Serial.println("Tag not authorized");
Serial.println(); // Blank separator line in output
bytesRead = 0;
* Fire the relay to activate the strike plate for the configured
* number of seconds.
void unlock() {
digitalWrite(ledPin, HIGH);
digitalWrite(strikePlate, HIGH);
delay(unlockSeconds * 1000);
* Search for a specific tag in the database
int findTag( char tagValue[10] ) {
for (int thisCard = 0; thisCard < numberOfTags; thisCard++) {
// Check if the tag value matches this row in the tag database
if(strcmp(tagValue, allowedTags[thisCard]) == 0)
// The row in the database starts at 0, so add 1 to the result so
// that the card ID starts from 1 instead (0 represents "no match")
return(thisCard + 1);
// If we don't find the tag return a tag ID of 0 to show there was no match
return(0);
i tried to change those cards but dint work ,there was nothing appearing in the serial monitor except " RFID reader starting up "
All the other replies started by saying they knew nothing about RFID,
Well I know a lot about RFID.
Unless you can understand the code you are grabbing off the Internet you are shooting in the dark as to if it will do what you want.
It is best if you learn how to code.
Tips:-
Convert the token strings into a number, the long long data type will hold 64 bits. That way your comparison is easy and you can do it in a simple if statement.
Grumpy_Mike:
can u help me out in converting the data type (dummy in programming =( )
even i was looking for that , i got the string data of my tag in serial monitor
These two functions will convert characters into a number:-
long int tokenInVar(){
long number = 0;
for(int i=0; i<8; i++) number = (number << 4) | convertFromHex(int(token[i]));
return(number);
long int convertFromHex(int ascii){
if(ascii > 0x39) ascii -= 7; // adjust for hex letters upper or lower case
return(ascii & 0xf);
It is designed to convert an 8 digit token but you can easily extend it by making the loop go round a few more times and changing the data type from long to long long.
RFID Cards have a 10 digit serial number and a 2 digit checksum
No not all only some.
Anyway it does not matter you can simply treat the check sum as two extra digits.
i tried with 15 different codes from the internet tried to replace my rfid tag details none of them worked
iam using em-18 rfid reader module (substitute for id-20 reader module)
i can able to scan the tags but couldn't able to make it use for proper authorization
found this online but still doesn't work with my tags
plz anyone help me out in figuring the actual problem :~ or can i get the complete code for making a rfid door acess system with 10 cards ,iam using arduino mega
## Modified code to work with Arduino 1.0.1Â /Â Â ##
## Credits to Petushka, http://www.instructables.com/member/Petushka/ ##
## Â Â Â ##
#define ADD_TAG_CODE "6B0037E8398D"Â //change this ID with your own card TAG
#define DEL_TAG_CODE "0800692B5D17"Â //change this ID with your own card TAG
SoftwareSerial rfid = SoftwareSerial(2, 3);
String msg;
String ID ;Â //string to store allowed cards
void setup()Â
 Serial.println("Serial Ready");
 rfid.begin(9600);
 Serial.println("RFID Ready");
char c;
void loop(){
Â
 while(rfid.available()>0){
  c=rfid.read();
  msg += c;
  Serial.println(msg);Â
  Serial.println(msg.length());
 msg=msg.substring(1,13);
 if(msg.indexOf(ADD_TAG_CODE)>=0) add();
 else if(msg.indexOf(DEL_TAG_CODE)>=0) del();Â
 else if(msg.length()>10) verifica();
 msg="";
Â
void add(){
 Serial.print("What TAG do you wanna grant access?: ");
 msg="";
 while(msg.length()<13){
   c=rfid.read();
   msg += c;
 if(ID.indexOf(msg)>=0) {
  Serial.println("\nAccess already granted for this card.");
  msg="";
 else{
  Serial.print("Card: ");
  ID += msg;
  ID += ",";
  //Serial.print("ID: ");
 // Serial.println(ID);
  msg="";
  Serial.println("Access granted for this card.");
void del(){
 msg="";
 Serial.print("What TAG do you wanna deny access?: ");
   c=rfid.read();
   msg += c;
 if(ID.indexOf(msg)>=0){
  Serial.println("TAG found. Access for this card denied.");
  //ID.replace(card,"");
  int pos=ID.indexOf(msg);
  msg="";
  msg += ID.substring(0,pos);
  msg += ID.substring(pos+15,ID.length());
  ID="";
  ID += msg;
  //Serial.println(ID);
 } else Serial.println("\nTAG not found or already denied");
 msg="";
void verifica(){
  if(ID.indexOf(msg)>=0) Serial.println("Access granted.");
 Â
  else Serial.println("Access denied.");
