Hello all,
I am new to Arduino and am working through the tutorials.
I am attempting to send the value of a float variable back to my debug screen through the serial port and it works fine using integer variables, but I get a compile error if I try it with a float variable. I have the Arduino NG rev. C and am using Arduino 0007 software.
Here's the code:
int value = 0;
float value3 = 0;
float value4 = 0;
int ledpinR = 3;
int ledpinG = 5;
Serial.begin(9600); // initialize serial communications at 9600 bps
for(value = 255; value >=0; value-=5) // fade red and blue out -> now dark
value3 = value / 2.55; // scale the brighter blue LED to the red values
value4 = value3 * 100; // multiply the float by 100 because of the Serial.println() truncate
analogWrite(ledpinR, value);
analogWrite(ledpinB, value3);
delay(50);
Serial.println(value4); // Changing this to output an int type works fine
When I compile this I get the error:
In function 'void loop()':
error: call of overloaded 'print(float&)' is ambiguous/Users/alan/local apps/arduino/arduino-0007/lib/targets/arduino/HardwareSerial.h:42: note: candidates are: void HardwareSerial::print(char)
void HardwareSerial::print(uint8_t)
void HardwareSerial::print(int)
void HardwareSerial::print(unsigned int)
void HardwareSerial::print(long int)
void HardwareSerial::print(long unsigned int)
I know that Serial.println() truncates float values to integers, but the error seems to suggest that I can only output chars and ints types. Do I have a syntax or initialization problem?
Any help would be most appreciated,
Alan
