Trouble with shift register, TPIC6B595N
Hi
I am using UNO, and following tutorials for the 74HC595 shift register and everything works fine.
I am now trying to use the TPIC5B595N in its place and I can not get any LED's to light.
The only thing I changed was the Data In and Clock position as the latch is on IC pin 12 on each chip.
Above is the lesson I am working with.
Thanks for any suggestions!
Mark
I see nothing above.
Ugh, sorry.
Hope this one works.
AFAIK the TPIC series all have open drain outputs, sinking only.
So connect your LED/resistors between supply (+5volt) and outputs.
Between outputs and ground won't work.
Leo..
That's it for sure. Thanks for pointing that out.
Mark
