Trouble with simple door alarm
Hello, I am trying to make a door alarm that will sound a siren and email me (via a php web page that is hosted on my server) and I am running into an issue with it. I should point out that this is my first Arduino project, and I am somewhat new to programming. The code verifies/compiles and uploads without issue to the Arduino. After the code is uploaded, nothing happens. If you guys have any ideas or suggestions; i would love to hear them.
Thanks.
Door Alarm
Simple alarm using a magnetic reed switch
with the arduino and ethernet shield
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(10,0,4,5);
IPAddress server(10,0,0,21);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
int doorpin = 9;
int alarmpin = 8;
int doorState = 0;
 pinMode(doorpin, INPUT);
pinMode(alarmpin, OUTPUT);
  // start the serial library:
  Ethernet.begin(mac,ip);
  // give the Ethernet shield a second to initialize:
void loop(){
 digitalWrite(alarmpin, HIGH); //The alarm is attached to a relay that will activate when the pin is pulled LOW, so I am turning it off here
  delay(10000); //wait ten secs to vacate
 doorState = digitalRead(doorpin);
 if (doorState == LOW) { //the reed switch is a normally closed one, so it goes LOW when the door is opened
 Serial.println("Door Opened");
 client.connect(server,80);
 client.println("GET /email.php HTTP/1.0");
 client.println();
 delay(10000);
 digitalWrite(alarmpin, LOW); // Turn relay and attached alarm on
How have you got this wired together? Do you get the message Door Opened in the serial monitor? Also, not sure why you are delaying for 10 seconds I would remove that unless you have a reason for it I am missing.
Pauly: How have you got this wired together? Do you get the message Door Opened in the serial monitor? Also, not sure why you are delaying for 10 seconds I would remove that unless you have a reason for it I am missing.
The doorpin is hooked up to a magnetic reed switch, that is normally closed. Meaning that if the reed switch and the magnet are together, there is a connection. The alarmpin is hooked to a relay that switches on the alarm, I have already tested the relay with another sketch; and it is functional. I do not receive the Door Opened message in the serial monitor.
int doorState = 0;
You have already declared doorState LOW in the header.
Try making it HIGH or declaring it as HIGH.
I tried your suggestion about declaring the state high, and now it is progressing to the door detection point. It looks like it is now having a issue with the connection to the server. I added the diagnostic code from the WebClient example and it reports to me that “Connection Failed” in the serial monitor. I do not understand, as the connection code was taken directly from another sketch I made for testing the web functionality and the code works in the other sketch. Maybe I messed something up while moving the code around. As it stands this is the complete code from the alarm sketch:
#include <SPI.h>
int doorpin = 9;
int alarmpin = 8;
int doorState = 1;
void loop(){
   if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.println();
  else {
    // kf you didn't get a connection to the server:
    Serial.println("connection failed");
Well, progress is good. Someone else will have to help you with the ethernet shield as I have not used one yet. Good luck.
Pauly: Well, progress is good. Someone else will have to help you with the ethernet shield as I have not used one yet. Good luck.
Thank you for all your help, it saved me from a lot of head scratching
Well, I was able to get the email notifications working, and now my issue is getting the alarm to sound. What I want it to do is if the door is opened, sound the alarm for 10 minutes; then reset. What happens is that after I upload the code, and then I open the door (make the door pin go LOW); I get the “Door Opened” message in the serial monitor, but nothing else happens. Again, if someone has any ideas or suggestions, I would be happy to hear them.
Here is my current code:
Door Alarm
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x07, 0x9E };
int doorpin = 9;
int alarmpin = 8;
int doorState = 1;
int alarmState = HIGH;
long previousMillis = 0;
long interval = 8000;  //changed to 8 sec. for testing
  // start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
void loop(){
// delay(10000); //wait ten secs to vacate
// Serial.println("Armed");
 /* commented out the go to web site portion until I get the alarm reliably working.
    client.println();
    Serial.println("disconnecting.");
    client.stop();
 if(currentMillis - previousMillis > interval) {
Serial.println("Sounding Alarm");
    // if the Alarm is off turn it on and vice-versa:
    if (alarmState == HIGH)
      alarmState = LOW;
      alarmState = HIGH;
      // set the alarm with the alarmState of the variable:
    digitalWrite(alarmpin, alarmState);
Decided to go in a new direction, instead of having the alarm on a timer, I am thinking that it would be best it the alarm ran while the door was opened. If I do this however, I need to find a way to limit the amount of emails the arduino will send, since it will send one once per loop. I was thinking of creating a state "email sent" and having it look at it before sending another email. Still figuring out how to implement this though.
