Pretty much have 4 outputs and two inputs. One single pushbutton is counted and then stored which then selects which mode to go to to control some LEDs in a strobe fashion. It's getting hung up in the first loop i think because the entire thing is unresponsive to button presses. Let me know what you guys think. Thanks
//inputs & outputs
const int pot = A0; // select the input pin for the potentiometer (Analog pin AD2)
int val = 0; // variable to store the value coming from the sensor to be used as time delay
const int button = 10; //mode button
const int led1 = 2; //white
const int led2 = 3; //green cluster
const int led3 = 4; //blue cluster
const int led4 = 5; //red cluster
//counter variables
int button_push_counter = 0; // counter for the number of button presses
int button_state = 0; // current state of the button
int last_button_state = 0; // previous state of the button
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(pot, INPUT);
pinMode(button, INPUT);
button_state = digitalRead(button); //reading from button switch
if (button_state != last_button_state)
button_push_counter++;
last_button_state = button_state;
switch (button_state)
case 0:
white_strobe();
case 1:
red_strobe();
case 2:
green_strobe();
case 3:
blue_strobe();
case 4:
all_strobe();
case 5:
crazy_routine();
case 6:
crazy_strobe();
case 7:
void white_strobe()
val = analogRead(pot); // read the value from the sensor
digitalWrite(led1, HIGH); // turn the ledPin on
delay(val); // stop the program for some time
digitalWrite(led1, LOW); // turn the ledPin off
void green_strobe()
digitalWrite(led2, HIGH); // turn the ledPin on
digitalWrite(led2, LOW); // turn the ledPin off
void blue_strobe()
digitalWrite(led3, HIGH); // turn the ledPin on
digitalWrite(led3, LOW); // turn the ledPin off
void red_strobe()
digitalWrite(led4, HIGH); // turn the ledPin on
digitalWrite(led4, LOW); // turn the ledPin off
void all_strobe()
void crazy_routine()
void crazy_strobe()
