Hey all, I am trying to wrap my head around the whole timer thing instead of delays and I thought I had it understood when I came up with this. I am trying to turn a servo from 45 to 95 to 135 back to 95 and back to 45 with a .35 second delay.
#include <Servo.h>
long previousMillis = 0; // will store last time LED was updated
long pause = 350; //pause delay
Servo servo;
servo.attach(9); // attach servo to pin 9
if(currentMillis - previousMillis) = pause)
servo.write(45);
if(currentMillis - previousMillis = pause*2)
servo.write(90);
if(currentMillis - previousMillis = pause*3)
servo.write(135);
if(currentMillis - previousMillis = pause*4)
servo.write(90);
I get the error
Skooter_01_servohead.ino: In function 'void loop()':
Skooter_01_servohead:17: error: expected primary-expression before '=' token
Skooter_01_servohead:17: error: expected `;' before ')' token
Skooter_01_servohead:21: error: lvalue required as left operand of assignment
Skooter_01_servohead:25: error: lvalue required as left operand of assignment
Skooter_01_servohead:29: error: lvalue required as left operand of assignment
brickparatrooper:
I get the error
It is always useful to Auto Format your code, not just to tidy it up but because it warns of extra left/right brackets and braces. This line was wrong in your codeif(currentMillis - previousMillis) = pause)The display of matching brackets (or not) should indicate that there is a mismatch. Incidentally, I think that jamming the if statement against the opening bracket does not help in seeing errors either.
Thank you all very much!! it was the ==. The ) was accidentally left there after I had stated to mess with the code to figure out what was wrong. Glad it was something simple, I was worried I just wasn't grasping it properly.
That's a little awkward way of doing it, and could be an issue down the road if you are doing things that might make the loop() skip a millis tick. The same thing can be accomplished with a single if statement for checking the time:
