Trouble with two way SPI communication
I’m having some trouble getting two Arduinos (Uno-Uno or Uno-Mega) to communicate over SPI.
I would like the Slave to to send one or more bytes to the Master. The bytes will eventually contain the status of sensors connected to the digital ports, possibly chaining a serie of arduinos. But for now I’m just content with sending a predefined byte back to the master.
I’ve set up two Arduino’s using the guide from Nick Gammon here. All 6 pins from the iscp port are connected one-on-one. The Master is powered of USB and connected to the serial.
Master code is this:
#include <SPI.h>
void setup (void) {
    digitalWrite(SS, HIGH);  // ensure SS stays high for now
    SPI.begin ();
void loop (void)
    SPI.beginTransaction (SPISettings (30000, MSBFIRST, SPI_MODE0));
    digitalWrite(SS, LOW);
    Serial.println(SPI.transfer(0), BIN);
    SPI.endTransaction();
    delay(2000);  // 2 second delay
Slave code is this:
byte clr;
void setup (void) {
    pinMode(MISO, OUTPUT);      // have to send on master in, *slave out*
    SPCR |= _BV(SPE);           // turn on SPI in slave mode
    SPCR |= _BV(SPIE);          // turn on interrupts
    clr = SPDR;
    SPDR = 0xd0;
// SPI interrupt routine
ISR (SPI_STC_vect) {
    byte c = SPDR;
    SPDR = 0xd0;
void loop (void) {
I’m expecting only lines of 11010000 bytes.
But I’m getting this:
0
0
0
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
0
0
0
11010000
11010000
11010000
11010000
0
0
0
0
1111111
11111111
11111111
11111111
11111111
Anyone knows what’s happening?
pvandegeer:
#include <SPI.h>
void setup (void) {
    SPI.begin ();
void loop (void)
Slave code is this:
byte clr;
void setup (void) {
pinMode(MISO, OUTPUT);      // have to send on master in, slave out
    clr = SPDR;
    SPDR = 0xd0;
    byte c = SPDR;
    SPDR = 0xd0;
void loop (void) {
I'm expecting only lines of 11010000 bytes.
But I'm getting this:
0
0
0
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
11111111
0
0
0
11010000
11010000
11010000
11010000
0
0
0
0
1111111
11111111
11111111
11111111
11111111
Anyone knows what's happening?
I would add a SPI.begin(); in the Slave’s setup, before you reconfigure it for ‘slave’ mode. I am unsure what the bit order, clock divisor are after a hardware reset. You are using the default SPI.begin() in the master, I recommend you use the same configs on the slave.
Chuck.
Nevermind... I'm a fool.
I connected all 6 iscp pins, thinking this covered all pins. But there's a reset pin there and not a SS pin.
Connected the SS pin as wel and everything is working beautifully. Even 3 arduino's in a row passing on their bytes in a chain.
Thanks for your reply anyway!
Pepijn
