Further investigation:
The call of avrdude in 1.0.5 is the following:
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/ttyACM99 -b115200 -D -Uflash:w:/tmp/build7461407692120111235.tmp/Button.cpp.hex:i
where
/usr/share/arduino/hardware/tools/avrdude is a symbolic link to avrdude -> ../../../../bin/avrdude
/usr/share/arduino/hardware/tools/avrdude.conf is a symbolic link to avrdude.conf -> /etc/avrdude.conf
With this call everything works fine.
The call of avrdude in 1.5.6/1.5.8-1 is the following:
/usr/share/arduino/hardware/tools/avr/bin/avrdude -C/usr/share/arduino/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P/dev/ttyACM99 -b115200 -D -Uflash:w:/tmp/build5989151706807845990.tmp/Blink.cpp.hex:i
where
/usr/share/arduino/hardware/tools/avr/bin/ is a symbolic link to bin -> ../../../../../bin
/usr/share/arduino/hardware/tools/avr/etc/ is a symbolic link to etc -> ../../../../../../etc
With this call i got the following error:
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 14:25:10
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/share/arduino/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/odroid/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM99
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
Probleme beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload .
In another test, i removed the link of /bin, created a directory bin and set all the nescessary symbolic links:
avr-ar -> ../../../../../../bin/avr-ar
avrdude -> ../../../../../../bin/avrdude
avr-g++ -> ../../../../../../bin/avr-g++
avr-gcc -> ../../../../../../bin/avr-gcc
avr-objcopy -> ../../../../../../bin/avr-objcopy
avr-size -> ../../../../../../bin/avr-size
Then i get the following log:
avrdude: Recv: . [10]
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x10
avrdude: Recv: . [14]
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xff
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00] [20]
It's all the same installation of avrdude, just the symlinking differs a bit...strange.
Any ideas?
Regards, Thorsten
