So I'm trying to use a slide switch to turn on and off a bot but. When I do not include the code for the switch:
while (digitalRead(switchpin) == HIGH)
digitalWrite(motor1forward, LOW);
digitalWrite(motor1backward, LOW);
digitalWrite(motor2forward, LOW);
digitalWrite(motor2backward, LOW);
Everything works as normal, my bot goes forward and when the ultrasonic sensor gets within a distance it will stop.
During this time the serial monitor continuously shows the distance being given to the computer.
But when I do include this piece of code, the switch in the HIGH position will keep the system off. When I put it to the other position, the bot will begin to move forward, but the ultrasonic sensor stops sending information to the bot and therefore does not stop after reaching a certain distance.
At the bottom I have include the full code. If there is an easier way to use the switch then that is fine. But basically I just need the switch to make the bot turn on or off. I have no idea why the switch makes the sensor not work.
#include <elapsedMillis.h>
int motor1forward = 12;
int motor1backward = 13;
int motor2forward = 2;
int motor2backward = 3;
const int trigPin = 4;
const int echoPin = 6;
long duration;
int distance;
int switchpin = 8;
elapsedMillis timeElapsed;
pinMode(motor1forward, OUTPUT);
pinMode(motor1backward, OUTPUT);
pinMode(motor2forward, OUTPUT);
pinMode(motor2backward, OUTPUT);
//pinMode(speed1Pin, OUTPUT);
//pinMode(speed2Pin, OUTPUT);
//digitalWrite(speed1Pin, HIGH);
//digitalWrite(speed2Pin, HIGH);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
while (digitalRead(switchpin) == HIGH);
while (timeElapsed >= 60000)
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration*0.034/2;
Serial.print("Distance: ");
Serial.println(distance);
if ( distance > 10 )
digitalWrite(motor1forward, HIGH);
digitalWrite(motor2forward, HIGH);
/*else if ( distance <= 10 )
digitalWrite(motor1backward, HIGH);
digitalWrite(motor2backward, HIGH);
delay(2000);
delay(1500);
