Hi
Im a total electronics and arduino newbee. To get into the basics of coding and using the aruino I ordered myself a starter kit and set practical goal. I suck at watering my plants so i wanted to build an automatic watering system. I know you could use all sorts of sensors but I believe those are unnecessary in my case. attached you find the scematics I pieced together with a local electronics hardware guy.
The code is really simple with "digitalWrite(2, HIGH), delay(), digital Write (2, LOW),......(other pins)"
Now the pumps follow my "Blink" routine but while one pump runs on max power the others are still working really slowly. Also not all the Pumps work at the same speed.
I would be really thankful for your feedback/help! The sceme is probably all messed up and I have no idea how to do a proper pull down resistor(as the hardware guy recommended). If you could tell me how to wire it up properly without using to many other components I would be very grateful! Sorry for my english.
Thank you in advance!!
Micha
