Trouble with WiFiWebClient
I got the following shield:
Now, I am trying to use it with Arduino UNO-R3 (IDE 1.0.5) and run the following example:
But, the call client.connect(server, 80) is returning false. The shield is connecting to the AP and getting the IP address.
Please note that I tried IP address as well.
Here, is the output:
Attempting to connect to SSID: 2WIRE891
Connected to wifi
SSID: 2WIRE891
IP Address: 192.168.1.75
signal strength (RSSI):-50 dBm
Starting connection to server...
disconnecting from server.
Downgrading to Arduino 1.0.3 solved the problem.
Seems there are more problems with Wifi shield :0
The wifi connection is not persistent. The connection goes on & off.
I am using the following library for building a WebSocket client:
The client worked fine on Ethernet. But with WiFi, client.connected() is returning false after couple of seconds.
Any suggestion?
