Trouble writing firmware for Nano IoT 33-like PCB "Error: at91samd21g18.cpu"
I'm a little new to all of this, so thanks in advance for your help!
Hi, I have built a modified version of the Arduino Nano IoT 33 (Just has a few extra ICs and connectors on the board). I'm trying to program the board such that I can upload a sketch via SWD (not USB)
Here's my approach
(Please tell me if anything's wrong with it)
  1. I've hooked up the "Arduino" via SWD pins and cable to a Particle debugger (this one: Particle Debugger – Particle Retail), which connects to my Mac via USB. I figured the debugger would be fine to use for uploading, as it follows CMSIS-DAP protocol.
  2. According to Arduino documentation (https://www.arduino.cc/en/Hacking/Programmer), I first attempted to burn the bootloader to create the fuses, and then I hit uploaded using programmer. To be clear, here were the exact steps:
  • Selected Tools > Board to "Arduino NANO IOT 33", programmer to "Atmel EDBG", and hit "Burn Bootloader"
  • Then, selected Sketch > Upload using programmer
Both result in some errors even though they attempt to write. I'll detail the errors below:
Step 1 (Burning bootloader):
See screenshot. Note the LED connected to the SCK pin pulsates once per sec at this point.
Step 2 (Uploading sketch)
See screenshot.
booth screenshots show successful programming. the Blink sketch blinks the LED
Thanks but there were still error messages. Any insight into those?
And also, the blinking doesn't happen until I click "Burn Bootloader" the 2nd time.
