Hey,
I am trying to simulate an HDMI testbench from Sameer's post here to understand and eventually use the HDMI module for my MKR VIDOR 4000 board.
However, when I compile this SystemVerilog code on Quartus I am getting an error that I do not understand how to solve
This is what Quartus keep logging :
Error (10170): Verilog HDL syntax error at top_tb.sv(114) near text: "for"; expecting "endmodule". Check for and fix any syntax errors that appear immediately before or at the specified keyword. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at FPGA Knowledge Base Articles Search and search for this specific error message number.
and here code ( block containing the error is marked with comments). Kindly help me understand what I am missing here.
Thank you in advance! Good day!
module top_tb();
timeunit 1ns;
timeprecision 1ns;
initial begin
#40ms $finish;
end
top top ();
logic [9:0] cx = 800 - 4;
logic [9:0] cy = 525 - 1;
logic [9:0] tmds_values [2:0] = '{10'dx, 10'dx, 10'dx};
logic [7:0] decoded_values [2:0];
logic [3:0] decoded_terc4_values [2:0];
genvar i;
genvar j;
generate
for (j = 0; j < 3; j++)
begin : check
assign decoded_values[j][0] = tmds_values[j][9] ? ~tmds_values[j][0] : tmds_values[j][0];
for (i = 1; i < 8; i++)
begin : check2
assign decoded_values[j][i] = tmds_values[j][8] ?
(tmds_values[j][9] ? (~tmds_values[j][i]) ^ (~tmds_values[j][i-1]) : tmds_values[j][i] ^ tmds_values[j][i-1])
: (tmds_values[j][9] ? (~tmds_values[j][i]) ~^ (~tmds_values[j][i-1]) : tmds_values[j][i] ~^ tmds_values[j][i-1]);
end
assign decoded_terc4_values[j] = tmds_values[j] == 10'b1010011100 ? 4'b0000
: tmds_values[j] == 10'b1001100011 ? 4'b0001
: tmds_values[j] == 10'b1011100100 ? 4'b0010
: tmds_values[j] == 10'b1011100010 ? 4'b0011
: tmds_values[j] == 10'b0101110001 ? 4'b0100
: tmds_values[j] == 10'b0100011110 ? 4'b0101
: tmds_values[j] == 10'b0110001110 ? 4'b0110
: tmds_values[j] == 10'b0100111100 ? 4'b0111
: tmds_values[j] == 10'b1011001100 ? 4'b1000
: tmds_values[j] == 10'b0100111001 ? 4'b1001
: tmds_values[j] == 10'b0110011100 ? 4'b1010
: tmds_values[j] == 10'b1011000110 ? 4'b1011
: tmds_values[j] == 10'b1010001110 ? 4'b1100
: tmds_values[j] == 10'b1001110001 ? 4'b1101
: tmds_values[j] == 10'b0101100011 ? 4'b1110
: tmds_values[j] == 10'b1011000011 ? 4'b1111
: 4'bzzzz;
end
endgenerate
always @(posedge top.clk_pixel)
begin
tmds_values[0] <= top.hdmi.tmds_internal[0];
tmds_values[1] <= top.hdmi.tmds_internal[1];
tmds_values[2] <= top.hdmi.tmds_internal[2];
end
logic [4:0] data_counter = 0;
logic [63:0] sub [3:0] = '{64'dX, 64'dX, 64'dX, 64'dX};
logic [31:0] header = 32'dX;
logic [19:0] N;
assign N = {sub[0][35:32], sub[0][47:40], sub[0][55:48]};
logic [19:0] CTS;
assign CTS = {sub[0][11:8], sub[0][23:16], sub[0][31:24]};
logic [23:0] L [3:0];
logic [23:0] R [3:0];
logic [3:0] PCUVr [3:0];
logic [3:0] PCUVl [3:0];
generate
for (i = 0; i< 4; i++)
begin : check3
assign R[i] = sub[i][47:24];
assign L[i] = sub[i][23:0];
assign PCUVr[i] = sub[i][55:52];
assign PCUVl[i] = sub[i][51:48];
end
endgenerate
logic [2:0] num_samples_present;
assign num_samples_present = 3'(header[11]) + header[10] + header[9] + header[8];
logic [$clog2(192)-1:0] frame_counter = 0;
logic [191:0] channel_status [1:0] = '{192'dX, 192'dX};
// PB0-PB6 = sub0
// PB7-13 = sub1
// PB14-20 = sub2
// PB21-27 = sub3
// returns number of non-zero elements in array
function int check_non_zero_elem(logic [7:0] a0);
check_non_zero_elem = 0;
for(int i=$low(a0); i <= $high(a0); i++)
if(a0[i] != 0) check_non_zero_elem++;
endfunction
// THE FOLLOWING BLOCK IS INDICATED AS HAVING THE ERROR
logic [7:0] packet_bytes [0:27];
for (i = 0; i < 28; i++)
begin
assign packet_bytes[i] = sub[i / 7][((i % 7) + 1) * 8 - 1 :(i % 7) * 8];
end
logic first_packet = 1;
logic first_audio_packet = 1;
logic [15:0] previous_sample [1:0];
integer k;
begin
cx <= cx == top.frame_width - 1 ? 0 : cx + 1;
cy <= cx == top.frame_width-1'b1 ? cy == top.frame_height-1'b1 ? 0 : cy + 1'b1 : cy;
if (top.hdmi.true_hdmi_output.num_packets_alongside > 0 && (cx >= top.screen_width + 8 && cx < top.screen_width + 10) || (cx >= top.screen_width + 10 + top.hdmi.true_hdmi_output.num_packets_alongside * 32 && cx < top.screen_width + 10 + top.hdmi.true_hdmi_output.num_packets_alongside * 32 + 2))
begin
assert(tmds_values[2] == 10'b0100110011) else $fatal("Channel 2 DI GB incorrect: %b", tmds_values[2]);
assert(tmds_values[1] == 10'b0100110011) else $fatal("Channel 1 DI GB incorrect");
assert(tmds_values[0] == 10'b1010001110 || tmds_values[0] == 10'b1001110001 || tmds_values[0] == 10'b0101100011 || tmds_values[0] == 10'b1011000011) else $fatal("Channel 0 DI GB incorrect");
end
else if (top.hdmi.true_hdmi_output.num_packets_alongside > 0 && cx >= top.screen_width + 10 && cx < top.screen_width + 10 + top.hdmi.true_hdmi_output.num_packets_alongside * 32)
begin
data_counter <= data_counter + 1'd1;
if (data_counter == 0)
begin
sub[3][63:1] <= 63'dX;
sub[2][63:1] <= 63'dX;
sub[1][63:1] <= 63'dX;
sub[0][63:1] <= 63'dX;
header[31:1] <= 31'dX;
if (cx != top.screen_width + 10 || !first_packet) // Packet complete
begin
first_packet <= 0;
case(header[7:0])
8'h00: begin
$display("NULL packet");
end
8'h01: begin
$display("Audio Clock Regen packet N = %d, CTS = %d", N, CTS);
assert(header[23:8] === 16'd0) else $fatal("Clock regen HB1, HB2 should be X: %b, %b", header[23:16], header[15:8]);
assert(sub[0] == sub[1] && sub[1] == sub[2] && sub[2] == sub[3]) else $fatal("Clock regen subpackets are different");
assert(N == 128*48000/1000) else $fatal("Incorrect N: %d should be %d", N, 128*48000/1000);
if (CTS == 24939)
$warning("CTS is out of spec, this should only happen once while warming up at the beginning of the testbench.");
assert(CTS == 25200 || CTS == 25199 || CTS == 24939) else $fatal("Incorrect CTS, should hover around 25200: %d", CTS);
end
8'h02: begin
$display("Audio Sample packet #%d - %d", frame_counter + 1, frame_counter + num_samples_present);
assert(header[12] == 1'b0) else $fatal("Sample layout is not 2 channel");
assert(header[11:8] == 4'd15 || header[11:8] == 4'd7 || header[11:8] == 4'd3 || header[11:8] == 4'd1) else $fatal("Sample present flag values unexpected: %b", header[11:8]);
assert(header[19:16] == 4'd0) else $fatal("Sample flat values nonzero: %b", header[19:16]);
for (k = 0; k < 4; k++)
begin
if (!header[8 + k]) // Sample not present
continue;
channel_status[1][frame_counter + k] = PCUVr[k][2];
channel_status[0][frame_counter + k] = PCUVl[k][2];
if ((frame_counter + k) % 192 == 0) // Last frame was end of IEC60958 frame, this sample starts a new frame
begin
if (!first_audio_packet)
begin
assert(channel_status[0] == top.hdmi.true_hdmi_output.packet_picker.audio_sample_packet.channel_status_left) else $fatal("Incorrect left channel status: %h should be %h", channel_status[0], top.hdmi.true_hdmi_output.packet_picker.audio_sample_packet.channel_status_left);
assert(channel_status[1] == top.hdmi.true_hdmi_output.packet_picker.audio_sample_packet.channel_status_right) else $fatal("Incorrect right channel status: %h should be %h", channel_status[1], top.hdmi.true_hdmi_output.packet_picker.audio_sample_packet.channel_status_right);
assert(previous_sample[0] - 1'd1 == L[k][23:8]) else $fatal("Expected left channel sample to be 1 less than previous: %d - 1 != %d", previous_sample[0], L[k][23:8]);
assert(previous_sample[1] + 1'd1 == R[k][23:8]) else $fatal("Expected right channel sample to be 1 greater than previous: %d + 1 != %d", previous_sample[1], R[k][23:8]);
end
first_audio_packet <= 0;
assert(header[20 + k] == 1'b1) else $fatal("Sample B value low for sample %d with counter %d", k, frame_counter);
end
assert(header[20 + k] == 1'b0) else $fatal("Sample B value high for sample %d with counter %d", k, frame_counter);
assert(PCUVr[k][1] == 1'b0 && PCUVl[k][1] == 1'b0) else $fatal("Sample user data bits nonzero");
assert(PCUVr[k][0] == 1'b0 && PCUVl[k][0] == 1'b0) else $fatal("Sample validity bits nonzero");
assert({PCUVr[k][3:0], R[k]} % 2 == 0) else $fatal("Sample right parity not even: %b", {PCUVr[k], R[k]});
assert({PCUVl[k][3:0], L[k]} % 2 == 0) else $fatal("Sample left parity not even: %b", {PCUVl[k], L[k]});
previous_sample = '{R[k][23:8], L[k][23:8]};
end
frame_counter <= (frame_counter + num_samples_present) % 192;
end
8'h82: begin
$display("AVI InfoFrame");
assert(packet_bytes.sum() + header[23:16] + header[15:8] + header[7:0] == 8'd0) else $fatal("Bad checksum");
assert(check_non_zero_elem(packet_bytes[14:27]) == 0) else $fatal("Reserved bytes not 0");
end
8'h83: begin
$display("SPD InfoFrame this is a %s created by %s that is a 0x%h", string'(packet_bytes[9:24]), string'(packet_bytes[1:8]), packet_bytes[25]);
assert(check_non_zero_elem(packet_bytes[26:27]) == 0) else $fatal("Reserved bytes not 0");
end
8'h84: begin
$display("Audio InfoFrame");
assert(packet_bytes[1] == 8'd1) else $fatal("Only channel count of 2 should be set");
assert(packet_bytes[2] == 8'd0 && packet_bytes[3] == 8'd0) else $fatal("These are refer to stream header");
assert(check_non_zero_elem(packet_bytes[6:27]) == 0) else $fatal("Reserved bytes not 0");
end
default: begin
$fatal("Unhandled packet type %h (%s) at %d, %d: %p", header[7:0], "Unknown", cx, cy, sub);
end
endcase
end
end
sub[3][{data_counter, 1'b1}] <= decoded_terc4_values[2][3];
sub[3][{data_counter, 1'b0}] <= decoded_terc4_values[1][3];
sub[2][{data_counter, 1'b1}] <= decoded_terc4_values[2][2];
sub[2][{data_counter, 1'b0}] <= decoded_terc4_values[1][2];
sub[1][{data_counter, 1'b1}] <= decoded_terc4_values[2][1];
sub[1][{data_counter, 1'b0}] <= decoded_terc4_values[1][1];
sub[0][{data_counter, 1'b1}] <= decoded_terc4_values[2][0];
sub[0][{data_counter, 1'b0}] <= decoded_terc4_values[1][0];
header[data_counter] <= decoded_terc4_values[0][2];
end
end
endmodule
