Hello, first time posting. Apologies if i haven't implemeted the ettiquette effectively.
I am hacking a cheep RC car. I am using an UNO and a H Bridge controller to drive 3 DC motors.
2 OFF drive the RC car, 1 OFF controls the steering.
THe wiring between the H Bridge controller, motors and Arduino are all confirmed to be correct. I have verified all the pin associations and confirm the correct operations of Pin HIGH/LOWs to get the required output for each function.
The trouble is implementing the use of millis() to time the on/off time of the motor drive.
Effectively I want to drive forward for a set period, then Turn right, drive forward, etc. repeating these steps to have the vehicle do a set circuit around the back yard.
below is the code (or at least should be, if i have used the TAGS correctly).
My trouble is i expect after the first IF statement in forward(); the motors to come on.
however i am finding that even when the comparison is TRUE the analog and digital write instructions seem to be skipped, and nothign happens.
I think it is in the equation 'currentMillis - prevousForwardMillis', as when i serial.print the result of that math the answer is always something like 4294953788, incrementing.
thoughts?
//variables that won't change
// For PWM maximum possible values are 0 to 255
const int motorSpeed = 200;
// Motor A connections
const int enA = 9; // steering speed
const int in1 = 8; // Left?
const int in2 = 7; //RIght?
// Motor B connections
const int enB = 3; // speed
const int in3 = 5; // forward?
const int in4 = 4; // back?
unsigned long previousForwardMillis = 0; //some global variables available anywhere in the program
unsigned long previousTurnMillis = 0;// puts a starting value for the variable
unsigned long currentMillis = 0;
unsigned long currentTurnMillis = 0;
unsigned long period = 245;// how long to pulse to get 1 wheel rotation
unsigned long distance = 8;// how many wheel rotations in 2000mm @ 245ms
unsigned long turnPeriod = 735;// how long a turn will take
#define EVER (;;);// an endless loop to use in the all stop function
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Turn off motors - Initial state
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
period = distance * period;
// this is the main program repeat area
currentMillis = millis();// capture the latest value of millis() this is equivalent to noting the time from a clock
forward();
void forward() {
if(currentMillis - previousForwardMillis < period){
analogWrite(enB, motorSpeed);
digitalWrite(in3, HIGH); //forward
if(currentMillis - previousForwardMillis >= period){
analogWrite(enB, 0);
digitalWrite(in3, LOW); //stops motors
previousForwardMillis += period;
Serial.print("currentMillis: ");
Serial.println(currentMillis);
Serial.print("previous ford Millis: ");
Serial.println(previousForwardMillis);
