Troubles uploading sketches with Arduinodroid
I tried to compile and upload simple sketches (LED blink and serial write) on a Arduino Nano board with Arduinodroid running on my ASUS tablet ok. Then I tried with a more complex sketch for BMP085 pressure sensor (the example sketch from Adafruit with external libraries) and I was able to compile, but not to upload. Upload starts ok but did non complete successfully. I tried using internal uploader, too with different delays in the range 50 to 1000 ms but in this case the upload doesn't start at all (unknown error). Did anyone experience the same with Arduinodroid and could please help me? Am I doing something wrong? Thanks a lot.
Hi all, I too have problems uploading sketches on arduino nano. If anyone does have some tips please share them with us!
I have got an arduino uno, and using it on my HTC Desire 816 with android version 5.0.2. Whenever i try to upload i get ab upload error:
CDC UART: Using Port: /dev/bus/usb/001/002 Using programmer: arduino Overriding Baud rate: 115200 failed to init libusb: -99 Error: Process returned not zero result code: 11
Any one knows how to get around this error?
cathy1991: I have got an arduino uno, and using it on my HTC Desire 816 with android version 5.0.2. Whenever i try to upload i get ab upload error:
Hi cathy,
I am trying to fix this problem which seems to be concerning many devices running Android Lollipop. I will be posting any progress made to this thread: http://forum.arduino.cc/index.php?topic=160105 and hope others do the same so that it gets fixed.
Happy coding, Joonas.
Hi to all, i've almost the same trouble. My error while try to upload sketch on my arduino clone (dcduino uno with ch340g chip) is: failed to set baud rate: -9 and something other timeouts. Did someone has the same error? Has someone solved this trouble? Does Arduinodroid work only with original arduino or someone can upload sketchs on a clone?
Thanks
