Troubles with combining codes
Heya peeps!
Currently, I’m working on a music box project. I’m using the touchboard from bare conductive along with an LED Stripe.
Basically, Im using the touchboard for the music element. when someone touches one of the sensors, the music changes. simple.
But then, I want to implement a lighting system alongside it. So the main idea is that the LEDs would react to the beat of the music. I havent gotten this to work without processing, so im scrapping this idea (unless you peeps have a solution!)
So now im just trying to get the LEDs to light up in random colours as the song plays.
The touchboard mp3 code is:
 Bare Conductive Touch MP3 player
 Touch_MP3.ino - touch triggered MP3 playback
 Based on code by Jim Lindblom and plenty of inspiration from the Freescale
 Semiconductor datasheets and application notes.
 Bare Conductive code written by Stefan Dzisiewski-Smith and Peter Krige.
 This work is licensed under a Creative Commons Attribution-ShareAlike 3.0
 Unported License (CC BY-SA 3.0) http://creativecommons.org/licenses/by-sa/3.0/
 THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
 AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
 OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
 THE SOFTWARE.
// compiler error handling
#include "Compiler_Errors.h"
// touch includes
#include <MPR121.h>
#include <Wire.h>
#define MPR121_ADDR 0x5C
#define MPR121_INT 4
// mp3 includes
#include <SPI.h>
#include <SdFat.h>
#include <SdFatUtil.h>
#include <SFEMP3Shield.h>
// mp3 variables
SFEMP3Shield MP3player;
byte result;
int lastPlayed = 0;
// mp3 behaviour defines
#define REPLAY_MODE TRUE  // By default, touching an electrode repeatedly will
                          // play the track again from the start each time.
                          // If you set this to FALSE, repeatedly touching an
                          // electrode will stop the track if it is already
                          // playing, or play it from the start if it is not.
// touch behaviour definitions
#define firstPin 0
#define lastPin 11
// sd card instantiation
SdFat sd;
void setup(){
  Serial.begin(57600);
  pinMode(LED_BUILTIN, OUTPUT);
  //while (!Serial) ; {} //uncomment when using the serial monitor
  Serial.println("Bare Conductive Touch MP3 player");
  if(!sd.begin(SD_SEL, SPI_HALF_SPEED)) sd.initErrorHalt();
  if(!MPR121.begin(MPR121_ADDR)) Serial.println("error setting up MPR121");
  MPR121.setInterruptPin(MPR121_INT);
  MPR121.setTouchThreshold(40);
  MPR121.setReleaseThreshold(20);
  result = MP3player.begin();
  MP3player.setVolume(10,10);
  if(result != 0) {
    Serial.print("Error code: ");
    Serial.print(result);
    Serial.println(" when trying to start MP3 player");
void loop(){
  readTouchInputs();
void readTouchInputs(){
  if(MPR121.touchStatusChanged()){
    MPR121.updateTouchData();
    // only make an action if we have one or fewer pins touched
    // ignore multiple touches
    if(MPR121.getNumTouches()<=1){
      for (int i=0; i < 12; i++){  // Check which electrodes were pressed
        if(MPR121.isNewTouch(i)){
            //pin i was just touched
            Serial.print("pin ");
            Serial.print(i);
            Serial.println(" was just touched");
            digitalWrite(LED_BUILTIN, HIGH);
            if(i<=lastPin && i>=firstPin){
              if(MP3player.isPlaying()){
                if(lastPlayed==i && !REPLAY_MODE){
                  // if we're already playing the requested track, stop it
                  // (but only if we're in REPLAY_MODE)
                  MP3player.stopTrack();
                  Serial.print("stopping track ");
                  Serial.println(i-firstPin);
                  // if we're already playing a different track (or we're in
                  // REPLAY_MODE), stop and play the newly requested one
                  MP3player.playTrack(i-firstPin);
                  Serial.print("playing track ");
                  // don't forget to update lastPlayed - without it we don't
                  // have a history
                  lastPlayed = i;
                // if we're playing nothing, play the requested track
                // and update lastplayed
                lastPlayed = i;
        }else{
          if(MPR121.isNewRelease(i)){
            Serial.print(i);
            Serial.println(" is no longer being touched");
            digitalWrite(LED_BUILTIN, LOW);
and the code for the LED (got it from Jerome Bernard: RGB Led Strip controlled by an Arduino) is:
// HSV fade/bounce for Arduino - scruss.com - 2010/09/12
// Note that there's some legacy code left in here which seems to do nothing
// but should do no harm ...
// don't futz with these, illicit sums later
#define RED       9// pin for red LED
#define GREEN    10 // pin for green - never explicitly referenced
#define BLUE     11 // pin for blue - never explicitly referenced
#define SIZE    255
#define DELAY    20
#define HUE_MAX  6.0
#define HUE_DELTA 0.01
//long deltas[3] = { 5, 6, 7 };
long rgb[3];
long rgbval;
// for reasons unknown, if value !=0, the LED doesn't light. Hmm ...
// and saturation seems to be inverted
float hue=0.0, saturation=1, value=1;
chosen LED SparkFun sku: COM-09264
 has Max Luminosity (RGB): (2800, 6500, 1200)mcd
 so we normalize them all to 1200 mcd -
 R  250/600  =  107/256
 G  250/950  =   67/256
 B  250/250  =  256/256
long bright[3] = { 107, 67, 256};
//long bright[3] = { 256, 256, 256};
long k, temp_value;
void setup () {
  randomSeed(analogRead(4));
  for (k=0; k<3; k++) {
    pinMode(RED + k, OUTPUT);
    rgb[k]=0;
    analogWrite(RED + k, rgb[k] * bright[k]/256);
  hue += HUE_DELTA;
  if (hue > HUE_MAX) {
    hue=0.0;
  rgbval=HSV_to_RGB(hue, saturation, value);
  rgb[0] = (rgbval & 0x00FF0000) >> 16; // there must be better ways
  rgb[1] = (rgbval & 0x0000FF00) >> 8;
  rgb[2] = rgbval & 0x000000FF;
  for (k=0; k<3; k++) { // for all three colours
  delay(DELAY);
long HSV_to_RGB( float h, float s, float v ) {
  /* modified from Alvy Ray Smith's site: http://www.alvyray.com/Papers/hsv2rgb.htm */
  // H is given on [0, 6]. S and V are given on [0, 1].
  // RGB is returned as a 24-bit long #rrggbb
  int i;
  float m, n, f;
  // not very elegant way of dealing with out of range: return black
  if ((s<0.0) || (s>1.0) || (v<1.0) || (v>1.0)) {
    return 0L;
  if ((h < 0.0) || (h > 6.0)) {
    return long( v * 255 ) + long( v * 255 ) * 256 + long( v * 255 ) * 65536;
  i = floor(h);
  f = h - i;
  if ( !(i&1) ) {
    f = 1 - f; // if i is even
  m = v * (1 - s);
  n = v * (1 - s * f);
  switch (i) {
  case 6:
  case 0:
    return long(v * 255 ) * 65536 + long( n * 255 ) * 256 + long( m * 255);
  case 1:
    return long(n * 255 ) * 65536 + long( v * 255 ) * 256 + long( m * 255);
  case 2:
    return long(m * 255 ) * 65536 + long( v * 255 ) * 256 + long( n * 255);
  case 3:
    return long(m * 255 ) * 65536 + long( n * 255 ) * 256 + long( v * 255);
  case 4:
    return long(n * 255 ) * 65536 + long( m * 255 ) * 256 + long( v * 255);
  case 5:
    return long(v * 255 ) * 65536 + long( m * 255 ) * 256 + long( n * 255);
  • The second piece of code has comments that seem to say the original programmer doesn't know how it works. If he doesn't know then don't expect to learn from him. Start from a base that is explainable by the original author.
  • The second piece of code uses delay() so you need to replace that first.
The Arduino is a poor choice for this project. Look at the MP3 code. It just starts and stops the music. It doesn't know when the beats are.
