Troubles with pwm pins 5 and 6 when using Mozzi on Arduino Nano
Hey guys,
If I often use this forum as visitor and never for asking questions, it’s probably because thanks to you, I find most of the time what i am looking for. But this time I need a bit help.
I’m working on arduino nano (made in China), making a small synthetiser with Mozzi library. I use 5 knobs to change FM synthesis parameters and fundamental frequency and I want to integrate 5 LED (connected to pwm pin 3 5 6 10 11 on my nano) fading when I play with the knobs.
Pins 3, 10 and 11 works fine but 5 and 6 only turn on when when potentiometres are on max (1023) as if this two pins were’nt PWM.
This is my code:
  Sketch based on the Mozzi exemple Knob_lightLevel_x2_FMsynth using 5 potentiometres to change FM synthesis parameters, and a knob for fundamental frequency,
  using Mozzi sonification library.
  Demonstrates analog input, audio and control oscillators, phase modulation
  and smoothing a control signal at audio rate to avoid clicks.
  Also demonstrates AutoMap, which maps unpredictable inputs to a set range.
  Mozzi exemple Knob_lightLevel_x2_FMsynth goes with a tutorial on the Mozzi site:
  http://sensorium.github.io/Mozzi/learn/Mozzi_Introductory_Tutorial.pdf
  The circuit:
     Audio output on digital pin 9 (on a Uno or similar), or
     check the README or http://sensorium.github.com/Mozzi/
     Potentiometer connected to analog pin 0.
       Center pin of the potentiometer goes to the analog pin.
       Side pins of the potentiometer go to +5V and ground
     Potentiometer connected to analog pin 1.
     Potentiometer connected to analog pin 2.
    Digital PWM Pin 11 has an LED connected to 220 ohm resitor on Arduino Nano board
    Digital PWM Pin 10 has an LED connected to 220 ohm resitor on Arduino Nano board
    Digital PWM Pin 6 has an LED connected to 220 ohm resitor on Arduino Nano board
    Digital PWM Pin 5 has an LED connected to 220 ohm resitor on Arduino Nano board
    Digital PWM Pin 3 has an LED connected to 220 ohm resitor on Arduino Nano board
  Mozzi help/discussion/announcements:
  https://groups.google.com/forum/#!forum/mozzi-users
  Tim Barrass 2013.
  This example code is in the public domain.
#include <MozziGuts.h>
#include <Oscil.h> // oscillator
#include <tables/cos2048_int8.h> // table for Oscils to play
#include <Smooth.h>
#include <AutoMap.h> // maps unpredictable inputs to a range
// desired carrier frequency max and min, for AutoMap
const int MIN_CARRIER_FREQ = 22;
const int MAX_CARRIER_FREQ = 440;
const int MIN = 1;
const int MAX = 10;
const int MIN_2 = 1;
const int MAX_2 = 15;
// desired intensity max and min, for AutoMap, note they're inverted for reverse dynamics
const int MIN_INTENSITY = 700;
const int MAX_INTENSITY = 10;
// desired mod speed max and min, for AutoMap, note they're inverted for reverse dynamics
const int MIN_MOD_SPEED = 10000;
const int MAX_MOD_SPEED = 1;
AutoMap kMapCarrierFreq(0,1023,MIN_CARRIER_FREQ,MAX_CARRIER_FREQ);
AutoMap kMapIntensity(0,1023,MIN_INTENSITY,MAX_INTENSITY);
AutoMap kMapModSpeed(0,1023,MIN_MOD_SPEED,MAX_MOD_SPEED);
AutoMap mapThis(0,1023,MIN,MAX);
AutoMap mapThisToo(0,1023,MIN_2,MAX_2);
const int KNOB_PIN1 = 0; // set the input for the knob1 to analog pin 0
const int KNOB_PIN2 = 1; // set the input for the knob1 to analog pin 1
const int KNOB_PIN3 = 2; // set the input for the knob1 to analog pin 2
const int KNOB_PIN4 = 3; // set the input for the knob1 to analog pin 3
const int KNOB_PIN5 = 4; // set the input for the knob1 to analog pin 4
const int analogOutPin1 = 11;
const int analogOutPin2 = 6;
const int analogOutPin3 = 10;
const int analogOutPin4 = 5;
const int analogOutPin5 = 3;
int outputValue1 = 0;        // value output to the PWM (analog out)
int outputValue2 = 0;        // value output to the PWM (analog out)
int outputValue3 = 0;        // value output to the PWM (analog out)
int outputValue4 = 0;        // value output to the PWM (analog out)
int outputValue5 = 0;        // value output to the PWM (analog out)
Oscil<COS2048_NUM_CELLS, AUDIO_RATE> aCarrier(COS2048_DATA);
Oscil<COS2048_NUM_CELLS, AUDIO_RATE> aModulator(COS2048_DATA);
Oscil<COS2048_NUM_CELLS, CONTROL_RATE> kIntensityMod(COS2048_DATA);
int mod_ratio = 5; // brightness (harmonics)
long fm_intensity; // carries control info from updateControl to updateAudio
// smoothing for intensity to remove clicks on transitions
float smoothness = 0.95f;
Smooth <long> aSmoothIntensity(smoothness);
void setup(){
  Serial.begin(115200); // set up the Serial output so we can look at the light level
  startMozzi(); // :))
void updateControl(){
  // read the knob4
  int freqVal = mozziAnalogRead(KNOB_PIN4); // value is 0-1023
  int FRQ = mapThis(freqVal);
   outputValue4 = map(freqVal, 0, 1023, 0, 255);
   // change the analog out value:
   analogWrite(analogOutPin4, outputValue4);
  // read the knob5
  int knob5 = mozziAnalogRead(KNOB_PIN5); // value is 0-1023
  int knob5Val = mapThis(knob5);
   outputValue5 = map(knob5, 0, 1023, 0, 255);
   analogWrite(analogOutPin5, outputValue5);
  // read the knob1
  int knob1_value = mozziAnalogRead(KNOB_PIN1); // value is 0-1023
   // map it to the range of the analog out:
   outputValue1 = map(knob1_value, 0, 1023, 0, 255);
   analogWrite(analogOutPin1, outputValue1);
    // map the knob to carrier frequency
  int carrier_freq = kMapCarrierFreq(knob1_value);
  //calculate the modulation frequency to stay in ratio
  int mod_freq = carrier_freq * mod_ratio * FRQ;
    // set the FM oscillator frequencies
    aCarrier.setFreq(carrier_freq);
    aModulator.setFreq(mod_freq);
      // print the results to the serial monitor:
      Serial.print("knob1 = " );
      Serial.print(knob1_value);
      Serial.print("\t output1 = ");
      Serial.println(outputValue1);
  // read the knob2
  int knob2_value= mozziAnalogRead(KNOB_PIN2); // value is 0-1023
    outputValue2 = map(knob2_value, 0, 1023, 0, 255);
    analogWrite(analogOutPin2, outputValue2);
      // print the value to the Serial monitor for debugging
      Serial.print("knob2 = ");
      Serial.print(knob2_value);
      Serial.print("\t"); // prints a tab
  int knob2_calibrated = kMapIntensity(knob2_value);
      Serial.print("knob2_calibrated = ");
      Serial.print(knob2_calibrated);
    // calculate the fm_intensity
    fm_intensity = ((long)knob2_calibrated * knob5Val * (kIntensityMod.next()+128))>>8; // shift back to range after 8 bit multiply
      Serial.print("fm_intensity = ");
      Serial.print(fm_intensity);
  // read the knob dependent resistor on the speed Analog input pin
  int knob3_value= mozziAnalogRead(KNOB_PIN3); // value is 0-1023
    outputValue3 = map(knob3_value, 0, 1023, 0, 255);
    analogWrite(analogOutPin3, outputValue3);
      Serial.print("knob3 = ");
      Serial.print(knob3_value);
  // use a float here for low frequencies
  float mod_speed = (float)kMapModSpeed(knob3_value)/1000;
      Serial.print("   mod_speed = ");
      Serial.print(mod_speed);
    kIntensityMod.setFreq(mod_speed);
      Serial.println(); // finally, print a carraige return for the next line of debugging info
int updateAudio(){
  long modulation = aSmoothIntensity.next(fm_intensity) * aModulator.next();
  return aCarrier.phMod(modulation);
void loop(){
  audioHook();
Any ideas?
At first I thought to an hardware problem, so I tryed this sketch and everything was well…
const int LED1 = 3;
const int LED2 = 5;
const int LED3 = 6;
const int LED4 = 10;
const int LED5 = 11;
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
  pinMode(LED3, OUTPUT);
  pinMode(LED4, OUTPUT);
  pinMode(LED5, OUTPUT);
  // LED 1
  for ( int i=10; i<=255; i++ ) {
    analogWrite(LED1, i);
    delay(1);
  for ( int i=255; i>=10; i-- ) {
    delay(1);
  // LED 2
    analogWrite(LED2, i);
    delay(1);
    delay(1);
  // LED 3
    analogWrite(LED3, i);
    delay(1);
    delay(1);
  // LED 4
    analogWrite(LED4, i);
    delay(1);
    delay(1);
  // LED 5
    analogWrite(LED5, i);
    delay(1);
    delay(1);
Certain timers are linked to certain PWM pins by the Arduino hardware. mozzi uses two and possibly three timers. It is likely that the timers used by mozzi are interfering with your usage of PWM.
Suggestion: Write a test program that controls PWM but does not use mozzi and see what happens with pins 5 and 6.
It looks like you already followed my suggestion. Great debugging!
Thx @vaj4088
I'll continue my investigations! If someone else has any solution, I am interested!
I think its all explained here http://sensorium.github.io/Mozzi/
See the Caveats and Work Around
Mozzi disables analogWrite() on pins 5 and 6 (Timer 0), 9 and 10 (Timer 1) in STANDARD mode. In HIFI mode, pins 3 and 11 (Timer 2) are also out. Pin numbers vary between boards.
There is an example here which bit bangs the pwm output https://github.com/sensorium/Mozzi/blob/master/examples/11.Communication/Sinewave_PWM_leds_HIFI/Sinewave_PWM_leds_HIFI.ino
Thx @cattledog
It doesn't sounds good to me but I'll work around and find a (other?) solution. I'll let you know!
Regards!
