Hi, I have a simple piece of code that was working perfectly on an Arduino duo/windows 10, and returning a stream of information to the computer via the serial interface at various baud rates.
I purchased a DUE board to increase the performance. I seem to be able to upload and compile code for the due successfully and set it running. The card connects to my machine reliably as com4. However, there seems to be no data coming back to my pc. I have tried different baud rates and always matched the pc and the card.
I read many issues but have no idea which are relevant. The board manager shows
Arduino SAM Boards (32-bits ARM Cortex-M3) by Arduino Version 1.6.11 INSTALLED
Thanks for your help.
// set up normalised raw input stream
for(int i=0; i < in_dimension; i++)
initial_raw_signal[i] = allRead(i);
void myprintfn ()
Serial.print(steps);
Serial.print(", \t");
steps = 0;
Serial.print(to_micros(updated_raw_signal[0]));
Serial.print(":");
Serial.print(to_micros(updated_signal[0]));
Serial.print(",");
for (int i=1; i < feature_dimension; i++)
Serial.print(updated_signal[i]);
//Serial.print(unscale(updated_signal[i], i));
Serial.print(",");
Serial.print("\n");
