TRoubleshooting Arudino ATMAGA1280
I just got my board three days ago for a project I am doing that uses pins 2-13 pwm's. The problem is that when I connect the board to my computer channel 11 stays on, even when the computer gets shut off. Im not asking for support for my project which I know this forum isn't about I know it has to do with the board. Pins 12 and 13 are no problem but its just pin 11.
Any help would be appreciated.
What do you mean by channel11? You should tell us a bit more about your program and circuit.
Cheers,
Kari
The program is a ambient lighting for my tv. I am using pins 2-13 (pwm's) on my arduino. I am sorry if I said Channel I was emailing the developer last night and and told him about my LED Channel. I meant to say pin 11. I made a circuit board that goes from the arduino pwm pins to a circuit board to power up my lights. Every pin works perfect except pin 11. Seems it is a constant ground due to my red light staying on. I tested my built circuit board numerous ways and everything seems to be ok. I am still learning about arduino boards so I am sorry if I am very noob-ish in this forum.
Still, code and circuit would help...
Cheers,
Kari
Here is the circuit diagram
And here is the code...
// Flags for the USB communication protocol
#define C_SF1 0xF1 // Startflag for 1-channel mode (1 RGB channel)
#define C_SF2 0xF2 // Startflag for 2-channel mode (2 RGB channels)
#define C_SF3 0xF3 // Startflag for 3-channel mode (3 RGB channels)
#define C_SF4 0xF4 // Startflag for 4-channel mode (4 RGB channels)
#define C_END 0x33 // End flag
#define C_ESC 0x99 // Escape character
// States for receiving the information, see the flow chart for more info
#define S_WAIT_FOR_SF 0
#define S_RECV_RGB 1
#define S_RECV_RGB_ESC 2
//--------------------------- FUNCTION DECLARATIONS -------------------------
// Receives bytes and returns true if a valid packet was received
boolean PacketReceived();
// Uses the rgb values to set the PWMs
void SetPWMs();
//--------------------------- VARIABLE DECLARATIONS -------------------------
int pulse = 0;
// State we are in: one of the S_* defines
int State = 0;
// The payload of a received message
int Payload[32];
// The amount of RGB values we have received
int ByteCount = 0;
// The character we received
int Recv;
// The amount of RGB channels we are using
int ChannelMode;
// PWM pins for channel 1
int r1_pin = 2;
int g1_pin = 3;
int b1_pin = 4;
// PWM pins for channel 2
int r2_pin = 5;
int g2_pin = 6;
int b2_pin = 7;
// PWM pins for channel 3
int r3_pin = 8;
int g3_pin = 9;
int b3_pin = 10;
// PWM pins for channel 4
int r4_pin = 11;
int g4_pin = 12;
int b4_pin = 13;
//----------------------------- IMPLEMENTATIONS -----------------------------
// initialize the serial communication
Serial.begin(256000); // opens serial port, sets data rate to 256000 bps
TCCR0B = TCCR0B & 0b11111000 | 0x2;
TCCR1B = TCCR0B & 0b11111000 | 0x2;
TCCR2B = TCCR0B & 0b11111000 | 0x2;
TCCR3B = TCCR0B & 0b11111000 | 0x2;
TCCR4B = TCCR0B & 0b11111000 | 0x2;
State = S_WAIT_FOR_SF;
if (Serial.available() > 0) {
if (PacketReceived()) {
SetPWMs();
boolean PacketReceived() {
Recv = Serial.read();
switch (State) {
case S_WAIT_FOR_SF:
// =============================== Wait for start flag state
switch (Recv) {
case C_SF1:
// Start flag for 1-channel mode
ChannelMode = 1;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case C_SF2:
// Start flag for 2-channel mode
ChannelMode = 2;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case 243://C_SF3:
// Start flag for 3-channel mode
ChannelMode = 3;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case C_SF4:
// Start flag for 4-channel mode
ChannelMode = 4;
State = S_RECV_RGB;
ByteCount = 0;
return false;
default:
// No action for all other characters
return false;
case S_RECV_RGB:
// =============================== RGB Data reception state
switch (Recv) {
case C_SF1:
ChannelMode = 1;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case C_SF2:
ChannelMode = 2;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case C_SF3:
ChannelMode = 3;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case C_SF4:
ChannelMode = 4;
State = S_RECV_RGB;
ByteCount = 0;
return false;
case C_END:
// End Flag
// For each channel, we should have received 3 values. If so, we have received a valid packet
if (ByteCount == ChannelMode * 3) {
ByteCount = 0;
return true; // <------------------------ TRUE IS RETURNED
else {
// Something's gone wrong: restart
ByteCount = 0;
return false;
case C_ESC:
// Escape character
State = S_RECV_RGB_ESC;
return false;
default:
// The character received wasn't a flag, so store it as an RGB value
Payload[ByteCount] = Recv;
ByteCount++;
return false;
case S_RECV_RGB_ESC:
// =============================== RGB Escaped data reception state
// Store the value in the payload, no matter what it is
ByteCount++;
State = S_RECV_RGB;
return false;
return false;
void SetPWMs() {
// Channel 1
analogWrite(r1_pin, Payload[0]);
analogWrite(g1_pin, Payload[1]);
analogWrite(b1_pin, Payload[2]);
// Channel 2
if (ChannelMode > 1) {
analogWrite(r2_pin, Payload[3]);
analogWrite(g2_pin, Payload[4]);
analogWrite(b2_pin, Payload[5]);
else {
// turn the rest to 0 (black)
analogWrite(r2_pin, 0);
analogWrite(g2_pin, 0);
analogWrite(b2_pin, 0);
analogWrite(r3_pin, 0);
analogWrite(g3_pin, 0);
analogWrite(b3_pin, 0);
analogWrite(r4_pin, 0);
analogWrite(g4_pin, 0);
analogWrite(b4_pin, 0);
// Channel 3
if (ChannelMode > 2) {
analogWrite(r3_pin, Payload[6]);
analogWrite(g3_pin, Payload[7]);
analogWrite(b3_pin, Payload[8]);
else {
// Channel 4
if (ChannelMode > 3) {
analogWrite(r4_pin, Payload[9]);
analogWrite(g4_pin, Payload[10]);
analogWrite(b4_pin, Payload[11]);
else {
The diagram of the circuit board shows only 3 channels and using pwm pins 2-10 but the developer of the software had written the code for another additional channel using pins 11-13.
Have tried pull down resistors? I don't know why only pin 11 behaves that way. Maybe somebody knows if it somehow different than the others, for me there's nothing special. Try to swap externally pin 11 with any other, maybe the problem is in soldering, problem should be "moved" to another pin. If not, there's problem with the arduino side.
Maybe...?
Cheers,
Kari
I went over the board numerous times and with spare parts (resistors, transitors) i made another board just for pin 11 with one resistor and one transistor so just so I know that nothing was touching nor was there any sort of issue with the parts, but still only pin 11 is grounded. Is it possible I bought a defective board?
Of course you disconnected the board and check it with multimeter, for shortcuts?
Kari
