Hello arduino folks!
For some weeks I've been working with my Automatic roller blind project and in this "update" I've added an ethernet module (ENC28J60). Almost everything works fine, but I got some small problems. I will include an amateur schematic and the code further down.
my problems:
- Sometimes when I click on the "Upp"(this means up in swedish) button on the website it sometimes receives the up command several times so the roller blind won't stop go up.
- I tried to set the IP address static which I can switch on and off by the "#define STATIC 1" line, the third line in the code.
This worked fine yesterday but now when I try to connect to it this morning it doesn't work, I have to automatically assign it an IP address and then it works. (The automatically assigned IP address wasn't the same as the static, it got a new one).
Is this something I can solve by altering the code? Thanks so much for the help!
I just have to mention that I have just altered a code that turns a LED on and off when the webbrowser requests the two different subpaths(?LED10=OFF and ?LED10=ON)
#include <EtherCard.h>
#include <Servo.h>
#define STATIC 1 // set to 1 to disable DHCP (adjust myip/gwip values below)
// mac address
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
// ethernet interface ip address
static byte myip[] = { 176,10,239,138 };
// gateway ip address
static byte gwip[] = { 176,10,236,1 };
// LED to control output
long upTime = 5000;
long downTime = 13500;
int ledPin10 = 2;
int servoPin = 9;
Servo EServo;
byte Ethernet::buffer[700];
char page[] PROGMEM =
"HTTP/1.0 503 Service Unavailable\r\n"
"Content-Type: text/html\r\n"
"Retry-After: 600\r\n"
"\r\n"
"<html>"
"<head>"
"<script>"
"function onFunction()"
"location.href='?LED10=ON'"
"function offFunction()"
"location.href='?LED10=OFF'"
"</script>"
"<title>"
"Erics automagiska rullgardinsdragare!"
"</title></head>"
"<body>"
"<h3>Erics automagiska rullgardin</h3>"
"<p><em>"
"<p id='demo'>Tryck på en av knapparna!</p>"
"<button type='button' onclick='onFunction()'>Upp</button>
"<button type='button' onclick='offFunction()'>Ner</button>"
"</em></p>"
"</body>"
"</html>"
void setup () {
pinMode(ledPin10, OUTPUT);
Serial.println("Trying to get an IP...");
Serial.print("MAC: ");
for (byte i = 0; i < 6; ++i) {
Serial.print(mymac[i], HEX);
if (i < 5)
Serial.print(':');
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println( "Failed to access Ethernet controller");
#if STATIC
Serial.println( "Getting static IP.");
if (!ether.staticSetup(myip, gwip)){
Serial.println( "could not get a static IP");
blinkLed(); // blink forever to indicate a problem
#else
Serial.println("Setting up DHCP");
if (!ether.dhcpSetup()){
Serial.println( "DHCP failed");
#endif
ether.printIp("My IP: ", ether.myip);
ether.printIp("Netmask: ", ether.mymask);
ether.printIp("GW IP: ", ether.gwip);
ether.printIp("DNS IP: ", ether.dnsip);
void loop () {
word len = ether.packetReceive();
word pos = ether.packetLoop(len);
// IF LED10=ON turn it ON
if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=ON") != 0) {
Serial.println("Received ON command");
digitalWrite(ledPin10, HIGH);
EServo.attach(servoPin);
EServo.write(178);
delay(upTime);
digitalWrite(ledPin10, LOW);
EServo.detach();
// IF LED10=OFF turn it OFF
if(strstr((char *)Ethernet::buffer + pos, "GET /?LED10=OFF") != 0) {
Serial.println("Received OFF command");
EServo.write(2);
delay(downTime);
EServo.detach();
// show some data to the user
memcpy_P(ether.tcpOffset(), page, sizeof page);
ether.httpServerReply(sizeof page - 1);
void blinkLed(){
while (true){
