I have two Arduino's connected together using I2C (SDA & SCL) to pass data from one to the other. It's not working correctly.
I added serial output throughout the program so I can see what is going on with the variables and other data.
I have to plug in the USB in one Arduino to view the serial and then move it to the other to view that serial data which cause the program to pause etc...
I have tried two USB cables which saves me the trouble switching cables but I have to change the serial port.
I like to view both sketches running at the same time.
Is there a method or technique that I can use to view the serial output from both Arduino's at the same time or is this the best way.
Thanks
Randy
