int variable = 0;
pinMode(A1, INPUT); //Photocell
pinMode(12, OUTPUT); //Led voltage
pinMode(6, OUTPUT); //Buzzer (PWM
float val;
float val = analogRead(A1);
if (val < 300) { // if it gets dark out
digitalWrite(12, 1); // LED turns on
digitalWrite(6, 0); // buzzer remains off
variable = 1;
else { // if its bright outside
digitalWrite(12, 0); // LED turns off
if (variable = 1) {
analogWrite(6, 10); // buzzer PWM turns on
delay(1000); // wait a second
digitalWrite(6, 0); // buzzer pin turns off
variable = 0;
Hey guys,
I am trying to use an input photocell voltage to control the output of an LED and a buzzer. The LED sub circuit works well, but the buzzer is not working properly. I want to have it buzz for one second, however once it turns on it does not turn off until val < 300 again. How can I fix the problem? Thank you in advance.
