Troubleshooting fast sample frequency
Hello,I'm new to arduino and have problem setting up my sample frequency.
I've got a working script for reading data at sample frequency 50 Hz. All the data is stored in a .csv file in processing.
Here is my arduino code:
const byte sensorPin = A0;
int reading = analogRead(sensorPin);
Serial.println(reading);
delay(20);
And My processing code:
import processing.serial.*;
Serial mySerial;
PrintWriter output;
int lf = 10; // Linefeed in ASCII
mySerial = new Serial( this, Serial.list()[3], 115200 );
output = createWriter( "sensordata.csv" );
void draw() {
if (mySerial.available() > 0) {
String value = mySerial.readStringUntil(lf);
if ( value != null ) {
if (value.length() > 2) {
output.print( value );
void keyPressed() {
output.flush(); // Writes the remaining data to the file
output.close(); // Finishes the file
exit(); // Stops the program
The problem is when I want to change my sample frequency to 200 Hz(even 100 Hz) isn't capturing all the samples in the csv file. When I capture 1 minute of data = 60*200= 12000 samples,I only got 3278 of samples equal to around 16 seconds. So where is The problem?
The only thing I changed from 50 Hz to 200Hz is changing the Arduino code with a delay of 5 ms=1/200 Hz
delay(5);
How are you changing the sample frequency?
void draw() {
Unlike the loop() function on the Arduino, draw() is NOT called over and over AS FAST AS POSSIBLE.
Therefore, you should NOT do serial IO in draw(). You should use mySerial.bufferUntil() in setup(), to define what constitutes a packet (lf is a fine terminator). Then, you should implement the serialEvent() method and do the serial IO there.
The serialEvent() method will be called as often as required, whenever a line feed arrives.
bn1234:
The biggest problem seems to be with your processing code.
I don't know about processing.
But in case you just want to log data to file, I'd simply use a "serial terminal program" and activate the "log to file" option, and all the data received will be saved to that file.
For Windows operating systems you can use Realterm logging serial data to a log file (without any programming, it is a user option).
A smaller problem occurs with your Arduino code: You are sending slightly slower than one sample every five milliseconds, because you forget, that
  • the analogRead() function call needs time
  • the loop() code needs some time
    But that is just a small error, you will perhaps send one sample in 5.2 milliseconds, or something like that.
Please let me know if you need Arduino code to send out samples exactly taken each 5.0 milliseconds.
I want to capture data at a 'known' sample frequency f.e 200 Hz,so thus sending out 5 ms. If the data sended is 5.2 ms,meaning 1/5.2ms=192.3077 Hz. That is also good, but I have to know the 'exact' sample frequency(the sample frequency should stay the same).
The reason why I ask, is because I want to process the captured data in MATLAB, and visualize the data over time, which is possible if I knew the exact sample frequency.
And the troubleshoot is indeed in processing, I'm going to look further for serial monitor software.
Kind Regards
bn1234:
Here is an Arduino code to keep a more accurate 5ms sample period than you get by using "delay()":
unsigned long lastSampleTime;
  if (micros()-lastSampleTime>=5000)
    lastSampleTime+=5000;
The accuracy is then the same as the accuracy of your Arduinos 16 MHz frequency clocking (16 MHz crystal or oscillator).
Thank you, are the units in microseconds : 5000 microseconds= 5 ms? Just curious, so I can adapt to any sample frequency I want
Yes, that is why micros() is called micros(). :slight_smile:
