Troubleshooting: I can hear relay clicking, but load doesn't transfer?
New to Arduino and cruised through the beginner projects included with the starter kit I bought...even managed to make a bunch of nifty improvements/mods while learning. Zero issues, until now.
I am making this project, and followed it to the letter. I did this several times - same result each time. I can hear the relay switching...but the load doesn't transfer from one output to the other.
Relay in question is aTianbo hjr-4102e-l-05v.
Note the schematic does not show a series resistor for the LEDs, make sure you use one.
Sounds like you have a wiring error.
Show us a good image of your wiring.
If it is wired up as in the drawing the LEDs are burned out. There might have been a short bright blink the first time the relay changed. You need something like a 1K to 10K resistor in series with the LED(s).
Are you sure the load is connected correctly? If you connect 5V to NO and the load to NC, it will never work. 5V OR the load must be connected to the C pin, and the other to NO or NC, depending on if you want to switch it on or switch it off.
Is the led orientated the correct way (Anode to positive, cathode to negative (ground)? Do you have a current limiting resistor in series with the led? If not, 5v will blow the led and make it junk.
Picture here.
rockorsmthn:
Picture attached.
Where?
Got dropped due to size; I put it up @ Imgur.
sdturner:
I have 560k resistors in there.
tinman13kup:
No, I'm not sure it's hooked up correctly! Can you see the picture (linked above) well enough to see how I've got it rigged?
LEDs are oriented correct way, and I've got resistors in there. I tested it with a separate 5V input: they both light up no problem.
A 560K resistor is huge for a series dropping value.
Use 220 red red brown or 330 orange orange brown or 470 yellow violet brown or 560 green blue brown.
The image is not good enough to determine how things are wired.
Looking at the pinout of the relay, it appears you have it miswired. Does the relay click as soon as you put power to the arduino?
According to the diagram I'm seeing, breadboard rows 9 on both sides are the NC and NO pins. Row 10 on both sides would be the coil (seem kind of close), and finally row 14 is the C pin.
@tinman13kup
You have better eyes than mine.
No, it doesn't click until the program tells it to.
I'm not familiar with what I've done wrong here - still trying to understand terms like NC, NO, C, etc.
larryd:
@tinman13kup
That's the new progressive bifocals at work. I can see the computer screen great (24"lcd), but as soon as I stand up and walk, I fall on my face....
Is this the pinout of the relay?
NO, NC, and C are the switching part of the relay. It's the reason you used the relay. C= Common pin, which is the 'common' pin regardless of the relay being on or off. With the relay off, the common pin connects to the NC (normally closed) pin. If you had 5v on the C pin, and the led attached to the NC pin, the led would stay lit until the relay is energized, which then connects the C pin to the NO (normally open) pin. If you had a different led on the NO pin, it would remain lit as long as the relay was energized.
The relay is energized with the coil. Placing 5V on one pin, and ground on the other causes the relay coil to become energized, and magnetic forces physically move contacts between the NO and NC pins.
That's the pinout I was looking at. The rest was in Chinese. Seems the pin numbers are a bit goofy
If that is the pinout, the breadboard wiring does not look even close.
