Troubleshooting printing strings using a for loop
Hi all,
The following code separates the words in a string so that if the character count on a line goes over 30, then it will move to the next line while keeping the word intact.
However, I can't figure out why its printing additional letters at the end of the string. What I have figured out, is that the number of unwanted characters it prints at the end, is the same as the number of lines that precede it. E.g. if 6 lines are printed, the 7th line will have 6 unwanted characters on it. I have no idea where these characters are coming from.
Here's the code:
const int length = 250; // The longest character length of any thought that will be passed through the program.
char thoughtStr[length] = "This is an example sentance that the string could contain, and the number of lines seems to match the number of unwated letters that are written at the end.";
byte numChar = 0; // Points to the character value in that element
byte numCharThought = 0; // Points to the element number in that thought
byte numCharPrinted = 0; // Points to the element number in that line
const byte paperWidth = 30; // Number of characters that can be printed per line.
byte endOfLastWord = 0;
byte endOfLastLine = 0;
byte newLineStr[15];
byte count = 0;
byte lastLineNum = 0;
byte lastCharNum = 0;
byte readyForNextLine = 0;
  printThought();
void loop()  {
void printThought() {
  for (int i = 0; i < length; i++) { // For the length of this thought:
    // Determine where line breaks will occur
    if (thoughtStr[i] == ' ' || thoughtStr[i] == '.') { // If the character is not a space or empty
      readyForNextLine = newLineStr[count] + paperWidth;
      if (i >= readyForNextLine || thoughtStr[i] == '.') { // If the current thought element is greater than 30 (0 to 30 is 31 characters. So 30 characters + the space or period.)
        if (i >= readyForNextLine) {
          count++;
          newLineStr[count] = endOfLastWord + 1;
          endOfLastWord = i - 1;
        } else if (thoughtStr[i] == '.') {
          count++;
          lastLineNum = count;
          lastCharNum = i;
      // Print the lines
      if (thoughtStr[i] == '.') { // If we're at the end of the thought, then print out the thought.
        for (byte k = 0; k < 15; k++) {
          for (byte z = newLineStr[k]; z < newLineStr[k + 1]; z++) {
            if (z != newLineStr[k] || z == 0) { // If we ARE on character 0 (which is a letter) or we're NOT on the space character (' ') that starts the next line
              Serial.print(thoughtStr[z]);
              if (z == lastCharNum - 1) { // If we're on the last character of the thought, then print a period.
                Serial.println(thoughtStr[z + 1]);
            } else { // If we ARE on the beginning of the line (which is a space charcter, and not a period), then make a line break to start a new line
Same idea here:
The QBF - "The Quick Brown Fox..." For Serial Diags - Community / Exhibition / Gallery - Arduino Forum
        case 13:                        // carriage return? Inplement as CR+LF
          c = 32 ;                      // SPACE character
          lcd.print(c) ;                // Print the CR/LF as a space
          for( int X = nLCD; X % 26 !=0; X++) lcd.print(c) ;  // clear to end of line with spaces
          nRow = (nLCD / 26) + 1 ;      // (row == 0, 1, ... 14)
          if( nRow > 15 ) nRow = 0 ;    // overflow: maintain boundary
          index = nRow ;                // array index for graphic "Y" position of first character
          nCol = 0 ;                    // "X" Graphic coordinate
          nRow = yCord[ index ]  ;      // Graphic "Y" coordinate via lookup
          nLCD = index * 26  ;          // 26 characters per line (line = nRow +1)
          lcd.setCursor (nCol, nRow) ;  // restore cursor to home character of current line
          // lFlag = false ;            // unneeded because nLCD %26 will == 0
          break ;
