Hello, I am trying to use Nick Gammon's RS485 library to send sensor (joystick) values from a master Arduino to a slave. For now, as a test, I am trying to display these values on the serial monitor connected to the slave to experiment with the idea of using rs485 for an ROV. The posted code is mostly modified from Gammon's example.
I am using the wiring shown here...
http://arduino-info.wikispaces.com/SoftwareSerialRS485Example
It uses modules based on the MAX485 chip and supporting components to make a half duplex network.
I am using hardware serial on an Arduino Uno for the master, and Serial1 hardware serial on an Arduino Mega for the slave.
I have not gotten any error messages from the IDE, but the sensor values are not getting displayed at the slave end by there serial monitor. My code is also attached.
Here is the code for the master.
#include "RS485_protocol.h"
int val = 0;
const byte ENABLE_PIN = 4;
// callback routines
void fWrite (const byte what)
Serial.write (what);
int fAvailable ()
return Serial.available ();
int fRead ()
return Serial.read ();
Serial.begin (28800);
pinMode (ENABLE_PIN, OUTPUT); // driver output enable
} // end of setup
val = analogRead (A0) / 4;
// assemble message
byte msg [] = {
5,
val
// to what level
// send to slave
digitalWrite (ENABLE_PIN, HIGH); // enable sending
sendMsg (fWrite, msg, sizeof msg);
delayMicroseconds (600);
digitalWrite (ENABLE_PIN, LOW); // disable sending
// Serial.println(val);
} // end of loop
And the code for the Slave... (will be underwater on the vehicle)
Serial1.write (what);
int fAvailable ()
return Serial1.available ();
int fRead ()
return Serial1.read ();
Serial1.begin (28800);
Serial.begin (9600);
byte buf [20];
byte received = recvMsg (fAvailable, fRead, buf, sizeof (buf) - 1);
// Serial.println(received);
if (received)
Serial.println(buf [0]);
Serial.println(buf [1]);
else{
Serial.println("not recieving anything");
delay(1);
// end of loop
Master_test.ino (739 Bytes)
Slave_test.ino (735 Bytes)
