Dear All,
I have made a post about controlling a SAA1099 sound chip with an Arduino Mega under a different topic last week and unfortunately didn't get any response, but with searching the forum and reading different articles, I managed to get it running. Then the real problems started and I'm at a loss of how to troubleshoot or find errors in the design...
Here's the chain of events. As I am a beginner, any pointer would be appreciated.
- Built the circuit on a breadboard.
- Uploaded the sketch.
- Didn't work, so I did research about the pins I used and changed from the port register method (using PORTD) to a function which just sets each pin to HIGH/LOW.
- It was working fine for a day and I played around with setting registers on the IC to modify the sound.
- Next day, no more sound output, but no change to circuit nor sketch.
- Also suddenly problems uploading any sketch to Arduino (avrdude timeout error).
- Suspected problem with pin 0 and 1, so changed wiring and sketch to use pin 30 to 37 instead.
- Uploading works again.
- IC still doesn't output any sound.
- Wired LEDs with 220 Ohm resistor to each output pin to see the communication. Now I hear a crackling noise in my headphones, every time a LED lights up.
The schematic and sketch are attached for reference.
Is it possible I blew something on my Arduino or my IC with the sketch/circuit?
const int PIN_WR = 44;
const int PIN_AO = 40;
const int PIN_CLOCK = 11; //Clock pin 11 on Arduino Mega 2560
const int PIN_BUS = 30; //start pin + 7
// B , C , C#, D , D#, E , F , F#, G , G#, A , A#
const byte freq[12] = { 2, 17, 34, 51, 69, 89,109,131,154,179,205,232};
// /WR active LOW
// /CS active LOW
// AO - LOW data to control register, HIGH address buffer
void chipSend(byte address, byte data) {
digitalWrite(PIN_AO, HIGH);
for (byte pin = 0; pin < 8; pin++) {
digitalWrite(PIN_BUS + pin, bitRead(address, pin));
digitalWrite(PIN_WR, LOW);
delayMicroseconds(5);
digitalWrite(PIN_WR, HIGH);
digitalWrite(PIN_AO, LOW);
digitalWrite(PIN_BUS + pin, bitRead(data, pin));
for (byte pin = PIN_BUS; pin < PIN_BUS + 8; pin++) {
digitalWrite(pin, LOW);
// the setup function runs once when you press reset or power the board
for (int i = 0; i < 14; i++) digitalWrite(i, LOW);
//setup 8Mhz time on OCA1 (Mega on pin 11)
pinMode(PIN_CLOCK, OUTPUT);
//setup Timer 1
TCCR1A = bit(COM1A0); //toggle OC1A on compare match
TCCR1B = bit(WGM12) | bit(CS10); //CTC no pre-scaling
OCR1A = 0; //output every cycle
//SAA1099 setup
pinMode(PIN_AO, OUTPUT);
pinMode(PIN_WR, OUTPUT);
//Setup output bus
pinMode(PIN_BUS + pin, OUTPUT);
digitalWrite(PIN_BUS + pin, LOW);
//Testing output pins
digitalWrite(PIN_BUS + pin, HIGH);
digitalWrite(PIN_WR, HIGH); //write disable
//Reset/Enable all the sound channels
chipSend(0x1C, B00000010);
chipSend(0x1C, B00000000);
chipSend(0x1C, B00000001);
//Disable the noise channels
chipSend(0x15, B00000000);
//Disable envelopes on Channels 2 and 5
chipSend(0x18, B00000000);
chipSend(0x19, B00000000);
chipSend(0x1C, 0b00000001); //sound enable all channels
for (byte ch = 0; ch < 6; ch++){
chipSend(ch+0x00, 0b11111111); //CH0-5 --> amplitude max D7-D4 right, D3- D0 left
//Setting octaves for CH0 to CH5
* 000 - 31 Hz to 61 Hz (lowest)
* 001 - 61 Hz to 122 Hz
* 010 - 122 Hz to 244 Hz
* 011 - 245 Hz to 488 Hz
* 100 - 489 Hz to 977 Hz
* 101 - 978 Hz to 1.95 kHz
* 110 - 1.96 kHz to 3.91 kHz
* 111 - 3.91 kHz to 7.81 kHz (highest)
//chipSend(0x10, B00110001); //X O1 O1 O1 X O0 O0 O0
//chipSend(0x11, B00010101); //X O3 O3 O3 X O2 O2 O2
//chipSend(0x12, B01100100); //X O5 O5 O5 X O4 O4 O4
chipSend(0x15, 0b00000000); //noise enable B(0 0 CH5 CH4 CH3 CH2 CH1 CH0)
//chipSend(0x16, B00000010);
//chipSend(0x16, B00NN00NN); //2 bits for noise generator control
chipSend(0x18, 0b00000000); //envelope generator 0 disabled
chipSend(0x19, 0b00000000); //envelope generator 1 disabled
for (byte oct = 0b00000011; oct < 0b00000101; oct++) {
chipSend(0x10, oct);
for (byte f = 0; f < 12; f++){
chipSend(0x08, freq[f]);
chipSend(0x14, 0b00000001);
delay(2000);
//chipSend(0x14, 0b00000000);
delay(10);
Troubleshooting Guidance Mega and SAA1099
