troubleshooting with a 9g servo
I am trying to control a 9g servo in a project that i am still working on, but whenever I run the code the servo just flicks in between what i assume the 2 positions are or it moves a bit then freezes. I know that it freezes in this certain part of the code because i have leds that will turn off when it runs through the servos.
anyways here is the part of the code where it freezes...
servo.write(90);
delay(5000);
servo.write(180);
delay(5000);
this is the full code...
#include <Servo.h>
Servo servo;
//rgb leds r in d7 d11 and d12
int redPin= 5;
int greenPin =11;
int bluePin =3;
int pos = 0; // variable to store the servo position
const int trigPin = 9;
const int echoPin = 10;
const int buzzer = 3;//needs PWM pins
long duration;//the time diffrence in bettween the trigger and echo
int distance;//the distance of the object
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
pinMode(trigPin, OUTPUT);//letting the pin know it will be used to send signals
pinMode(echoPin, INPUT);//letting it know it will be used to receive signals
Serial.begin(9600);//lets the serial monitior know that we r watching
pinMode(buzzer, OUTPUT);
servo.attach(8);
servo.write(180);
digitalWrite(trigPin,LOW);//turns off trig pin
delayMicroseconds(2);//short delay
digitalWrite(trigPin,HIGH);//turns on trig pin
delayMicroseconds(10);
//sends the package of signal for a short time
duration = pulseIn(echoPin,HIGH);//read the echo pin and return the sound wave travel time in microsecond
distance = duration* 0.034/2;//converts the duration into the distance to the object
Serial.print("distance: "); Serial.println(distance);//printing the value of the distance from the sensor to the object
if (distance <20)
setColor(0,100,0);
delay(3000);
setColor(100,100,0);
setColor(100,0,0);
servo.write(90);
delay(5000);
servo.write(180);
delay(5000);
setColor(0,0,0);
delay(10);
void setColor(int redValue, int greenValue, int blueValue) {
analogWrite(redPin, redValue);
analogWrite(greenPin, greenValue);
analogWrite(bluePin, blueValue);
See Read this before posting a programming question and follow the instructions on how to post code
Please post code between code tags
[code] and [/code]
Please provide a wiring diagram (photo (between 100 and 200 kB max) of hand-drawn one is OK). Specifically how you power everything is important.
95% of problems people have with servos are due to inadequate powering of the servo.
How are you powering your servo?
MarkT:
i am powering it using the arduino
creatingaccountjusttoaskaquestio:
That won't work 99% of the time. I have made that work with a micro servo - but that was just for testing. I would never put that into a project.
From the look of your code you are also powering quite a few other things through the Arduino including probably a buzzer. Powering servos that way is never a good idea and powering loads of other things as well makes it worse. And how is the Arduino powered? USB or external?
Try 4 x AA batteries for the servo power. + to servo +, - to servo - AND to Arduino GND.
Steve
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Please include how you are powering your project.
