Hi, sorry if I'm not posting in the right place, this is my first post. I'm trying to create a simple button box, for games like elite dangerous. I've already managed to use the same sketch for another project, but now I can't. I always get the same error when I verify the sketch: dod_button_box_code_v3:62:1: error: expected declaration before '}' token
exit status 1
If someone can help me it would be great
Here is the original code :
#include <Keypad.h>
#include <Joystick.h>
//DEFINITIONS
#define ENABLE_PULLUPS
#define NUMBUTTONS 17 //replace "?"with number of buttong you are using
#define NUMROWS 4 //replace "?" with number of rows you have
#define NUMCOLS 5 //replace "?" with number of columns you have
//BUTTON MATRIX
//first change number of rows and columns to match your button matrix,
//then replace all "?" with numbers (starting from 0)
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4},
{5,6,7,8},
{9,10,11,12},
{13,14,15,16}
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
//BUTTON MATRIX PART 2
byte rowPins[NUMROWS] = {1,2,3,4}; //change "?" to the pins the rows of your button matrix are connected to
byte colPins[NUMCOLS] = {12,11,10,9,8}; //change "?" to the pins the rows of your button matrix are connected to
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
//JOYSTICK SETTINGS
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK,
32, //number of buttons
0, //number of hat switches
//Set as many axis to "true" as you have potentiometers for
false, // y axis
false, // x axis
false, // z axis
false, // rx axis
false, // ry axis
false, // rz axis
false, // rudder
false, // throttle
false, // accelerator
false, // brake
false); // steering wheel
const int numReadings = 20;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int currentOutputLevel = 0;
