Troubling problem more lines in the coded added, then less power?
Hello experts
I have this weird problem with my relay project
I have 9 different inputs, they are supposed to turn on and off either one or both of the relays
However...
When I add more functions than two in the programming, the relays will not activate, and will instead just emit light from the status LEDS
It is a "standard" dual LED relay board, and in itself i works well
if I only have one function in the code, then there is no problem, if i add a function more, the "click" from the relays are dimmer
if I add even more (more than two), the relays will not even give a "click" sound but just emit a dim light from the status LEDS
It should be said, I have very little programming skills, and because of the problem escalates, depending of lines of code the I will assume the problem is in the coding
The circuit is quite large, but all input/outputs have been tried individually to rule out a bad or floating input/output with no problem, several power supply's have also been tried, with no different result
I really need some help, thank you
I do hope I have put this under the right segment
There are right now 4 of what I describe as functions
They are called "knap" it means button in danish, and that also will explain if my english writing might be a little off
const int LEDPin1 = 5;
const int relayPin1 = 2;
const int relayPin2 = 11;
const int buttonPin1 = A0;
const int buttonPin2 = A1;
const int buttonPin3 = A2;
const int buttonPin4 = A3;
const int buttonPin5 = A4;
const int buttonPin6 = A5;
int buttonState = 0;
  pinMode(relayPin1, OUTPUT);
  pinMode(relayPin2, OUTPUT);
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(buttonPin3, INPUT);
  pinMode(buttonPin4, INPUT);
  pinMode(buttonPin5, INPUT);
  pinMode(buttonPin6, INPUT);
//Motorstart
  buttonState = digitalRead(buttonPin4);
  if (buttonState == HIGH) {
    digitalWrite(relayPin1, LOW);
    digitalWrite(relayPin2, LOW);
    digitalWrite(LEDPin1, HIGH);
  else {
    digitalWrite(relayPin1, HIGH);
    digitalWrite(relayPin2, HIGH);
    digitalWrite(LEDPin1, LOW);
//Motorstart
//Knap 1
  buttonState = digitalRead(buttonPin1);
  else {
//Knap 1
//Knap 2
  buttonState = digitalRead(buttonPin2);
  else {
//Knap 2
//Knap 3
  buttonState = digitalRead(buttonPin3);
  else {
//Knap 3
//Knap 4
  else {
//Knap 4
What are the secifications of the power supply for the relay coils?
How are the buttons wired?
Please post a schematic showing all components and power supplies.
You only have one buttonState although you have many buttonPin1/2/3 etc.
So buttonState is being updated a gazillion times a second as it loop()s, and relays can't keep up.
Quick fix is to use buttonState1/2/3 etc.
Longer term fix is use arrays.
Hello Thank you for your answers
@ twinkleyan
unfortunately I do not have the competence to set it up as arrays, and it did not help my situation with the buttonstate change.
However i have found a solution using a NPN to assist the dual relay, and what I can google, there seems to be som issues with these cheap relay modules, especially the dual
@groundFungus
The buttons where wired with ground goingto the one connectoer, and the other connector has the wire for input, and a 10k resistor to VCC (5V)
And I have used a USB connection as power supply, a Boost converter, and also a PSU from a computer, used as a standalone PSU, så it should not be a power issue. I have got it working now, but with a resistor
Again, thank you for your contribution for a solution
Time to learn arrays, its pretty straightforward.
