Hi, everyone, I'm truing to create a simple ibutton reader using LCD shield with the code below:
#include <LiquidCrystal.h>
#include <OneWire.h>
OneWire ibutton (2); // I button connected on PIN 2.
byte buffer[20]; //array to store the Ibutton ID.
//LCD pin to Arduino
const int pin_RS = 8;
const int pin_EN = 9;
const int pin_d4 = 4;
const int pin_d5 = 5;
const int pin_d6 = 6;
const int pin_d7 = 7;
const int pin_BL = 10;
LiquidCrystal lcd( pin_RS, pin_EN, pin_d4, pin_d5, pin_d6, pin_d7);
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.print("Waiting");
lcd.setCursor(0,1);
// Serial.begin(9600);
lcd.setCursor(0,1);
if (!ibutton.search (buffer)){//read attached ibutton and asign value to buffer
ibutton.reset_search();
delay(200);
lcd.print("not found");
return;
for (int x = 4; x>0; x--){
lcd.print(buffer[x],HEX); //print the buffer content in LSB. For MSB: for (int x = 8; x>0; x--)
lcd.print(" "); // print a space
// int x;
// x = analogRead (0);
// lcd.setCursor(0,1);
// if (x < 60) {
// lcd.print ("Right ");
// else if (x < 200) {
// lcd.print ("Up ");
// else if (x < 400){
// lcd.print ("Down ");
// else if (x < 600){
// lcd.print ("Left ");
// else if (x < 800){
// lcd.print ("Select");
This works without LCD shield but when I install it I get gibberish in serial output!
thank you for any help
