I have build a Arduino based data GPS data transmitter.The device takes the GPS co-ordintates and sends the same to the Web though GPRS connection.
It is basically using Arduino Mega 2560,GPS module,SIM900 based GPRS module.The device is powered using the Truck battery itself after some smoothing of the voltage I have given 9V supply individual supplies to these three devices.It did work for 3 days straight sending me the co-ordinates once in 15s to my queue.The truck has been moving around the city only for the entire span of three days and the signal GPRS seem to bit good.
On the fourth day,the truck went to some remote place and the GPRS signal seems to be weak in that area.The msgs stop intermediately and starts re-transmission automatically.I did observe the following.
The GPS device is able to get the fix and it is working fine
The GPRS signal is weak(Could see in the mobile),but still when I call up the device ,I am able to get the ringing ,I am trying to establish that the GPRS module is responsive.
When I restart the Arduino,I am able to get the messages again.But after few minutes it stops again(No pattern in the stopping).
When I check the Arduino's Serial through which the device logs about itself,in a computer.The logging seems to be normal.I am trying to establish that the Arduino program is not hung.
Arduino Mega Is getting heated up than normal.
What could possibly be going wrong here? only the GPRS signal ?
I presume you meant to say that the Mega is heating up MORE than normal. I can't think why that should be, just because the phone signal is weak.
I'm not very clear about your electrical connections - can you post a diagram (photo of a pencil sketch) with part numbers included.
Phones use considerably more power when the signal is weak.
You haven't posted your code but you may need to include in it provision for loss of phone signal so that it can re-establish connection when the signal improves.
I guess for the Scenario you have asked,the message will be lost.In the next loop run,the new co-ordinates will be sent.
Right now ,the truck has moved and the data is getting logged now in the Queue.I think it is a problem with the GPRS signal only because of the remote area.
