try gsm lib in mega2560 not work
Try read SMS not work in Arduino mega2560, use pin 10 and 11 (tx,rx). help me please
GPRS_SMSread.ino (1.59 KB)
Please insert your code in the post, not as an attachment. It's small enough and people with e.g. cell phones will more than likely not be able to view it if it's attached.
Type
** **[code]** **
Paste your code after that
Type
** **[/code]** **
after that
So it looks like (beryindo's code, done it for you this time)
GPRS SMS Read
This sketch is used to test seeeduino GPRS_Shield's reading SMS
function.To make it work, you should insert SIM card
to Seeeduino GPRS Shield,enjoy it!
There are two methods to read SMS:
  1. GPRS_LoopHandle.ino  -> in order to recieve "+CMTI: "SM""
      may be you need to send this command to your shield: "AT+CNMI=2,2,0,0,0"
  2. GPRS_SMSread.ino -> you have to check if there are any
      UNREAD sms, and you don't need to check serial data continuosly
create on 2015/05/14, version: 1.0
by op2op2op2(op2op2op2@hotmail.com)
#include <GPRS_Shield_Arduino.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#define PIN_TX    10
#define PIN_RX    11
#define BAUDRATE  9600
#define MESSAGE_LENGTH 160
char message[MESSAGE_LENGTH];
int messageIndex = 0;
char phone[16];
char datetime[24];
GPRS gprsTest(PIN_TX,PIN_RX,BAUDRATE);//RX,TX,PWR,BaudRate
  while(!gprsTest.init()) {
      Serial.print("init error\r\n");
  delay(3000);
  Serial.println("Init Success, please send SMS message to me!");
   messageIndex = gprsTest.isSMSunread();
   if (messageIndex > 0) { //At least, there is one UNREAD SMS
      gprsTest.readSMS(messageIndex, message, MESSAGE_LENGTH, phone, datetime);
      //In order not to full SIM Memory, is better to delete it
      gprsTest.deleteSMS(messageIndex);
      Serial.print("From number: ");
      Serial.println(phone);
      Serial.print("Datetime: ");
      Serial.println(datetime);
      Serial.print("Recieved Message: ");
      Serial.println(message);
thank you sterretje, can you help for my case ?
You have some undefined external hardware connected in some undefined way to the Arduino. The code that you posted does something that you did not describe. You expect it to do something that you did not describe.
Hardly seems likely, does it?
