Try pressing MASTER_RESET button
After 1h reading post and tray solution ...
First choise ----> I am tempted to take car battery and place cable on CS waiting fo blue smoke .. "i love IC smoke in the morning"
Second choise ...ASK FOR HELP.
BN: Arduino/Genuino 101
VID: 8087
PID: 0AB6
SN: AE6771SQ54700M0
Sketch uses 17,648 bytes (11%) of program storage space. Maximum is 155,648 bytes.
Forcing reset using 1200bps open/close on port /dev/ttyACM0
/home/carmelo/.arduino15/packages/Intel/tools/arduino101load/1.6.9+1.28/arduino101load/arduino101load /home/carmelo/.arduino15/packages/Intel/tools/arduino101load/1.6.9+1.28/x86/bin /tmp/buildc664547d8d6f421b438075d52c0f1141.tmp/Blink.ino.bin /dev/ttyACM0 verbose ATP1BLE000-1541C5635 141312
Starting download script...
Args to shell: [/home/carmelo/.arduino15/packages/Intel/tools/arduino101load/1.6.9+1.28/x86/bin /tmp/buildc664547d8d6f421b438075d52c0f1141.tmp/Blink.ino.bin /dev/ttyACM0 verbose ATP1BLE000-1541C5635 141312]
Serial Port: /dev/ttyACM0
BIN FILE /tmp/buildc664547d8d6f421b438075d52c0f1141.tmp/Blink.ino.bin
Waiting for device...
Flashing is taking longer than expected
ERROR: Timed out waiting for Arduino 101 on /dev/ttyACM0
on Linux MINT 64bit
in the directory SCRIPS
i find this ???
carmelo@mintone ~/.arduino15/packages/Intel/tools/arduino101load/1.6.9+1.28/scripts $ dir ~/.arduino15/packages/Intel/tools/arduino101load/1.6.9+1.28/scripts/
create_dfu_udev_rule
Usage: create-cracklib-dict [options] wordlist ...
This script takes one or more word list files as arguments
and converts them into cracklib dictionaries for use
by password checking programs. The results are placed in
the default compiled-in dictionary location.
If you wish to store the dictionary in a different location,
use the cracklib-format and cracklib-packer commands directly.
Options:
-o, --output Alternative output file for cracklib-packer
-h, --help This help output
Example:
create-cracklib-dict /usr/share/words
install old board (1.04)
open terminal
cd ~/.arduino15/packages/Intel/tools/sketchUploader/1.6.4+1.14/scripts
sudo ./create_dfu_udev_rule
update board
