trying 2 loops
Hi all, newbie to arduino here. I was eperimenting with some different functions and i found this: http://arduino.cc/en/Tutorial/MultipleBlinks. Idea is pretty basis but yet i’m stuck. Void loop works seperatly but when i try to add scheduler for void loop2 (line28) i get an error saying 'expected unqualified-id before ‘.’ token.
I only am trying to blink led on pin 1 seperate from the main loop for a project i am planning. Hope some can give me advice ! Thx.
Code:
#include <Scheduler.h>
//VARS
//the time we give the sensor to calibrate (10-60 secs according to the datasheet)
int calibrationTime = 30;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 7; //the digital pin connected to the PIR sensor’s output
int ledPin = 8;
//SETUP
void setup(){
pinMode(pirPin, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(1, OUTPUT);
Scheduler.startLoop(loop2);
digitalWrite(pirPin, LOW);
//give the sensor some time to calibrate
Serial.print(“calibrating sensor “);
for(int i = 0; i < calibrationTime; i++){
Serial.print(”.”);
Serial.println(" done");
Serial.println(“SENSOR ACTIVE”);
delay(50);
//LOOP
void loop(){
if(digitalRead(pirPin) == HIGH){
digitalWrite(ledPin, HIGH); //the led visualizes the sensors output pin state
if(lockLow){
//makes sure we wait for a transition to LOW before any further output is made:
lockLow = false;
Serial.println("—");
Serial.print(“motion detected at “);
Serial.print(millis()/1000);
Serial.println(” sec”);
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
digitalWrite(ledPin, LOW); //the led visualizes the sensors output pin state
if(takeLowTime){
lowIn = millis(); //save the time of the transition from high to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we assume that no more motion is going to happen
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print(“motion ended at “); //output
Serial.print((millis() - pause)/1000);
delay(50);
void loop2() {
digitalWrite(1, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(1, LOW); // turn the LED off by making the voltage LOW
check the "blink without delay" example how to merge multiple pieces of code without the use of the BLOCKING delay function.
The demo several things at a time is an extended example of the BWoD technique.
...R
thanks for your guidance, code is working now! on to the next challenge :slight_smile:
