trying to add a second servo
ok here is what i’m doing. i’ve made a coding to control one servo to sweep from position 90, being 90 degrees to go to position 174 and back on a single push button. what i’m trying to do is add another servo on a different pin and controlled by the same button, i’m thinking pin 6 and i want that servo to sweep from 90 degrees to 6 degrees, the opposite direction. here is the code for the one servo. any help will be appreciated. thank you.
#include <Servo.h>
int inputPin = 10; // Push button input pin
int btnVal = 0; // Current value of pushbutton
int ledPin = 13; // Pin for white LED
int outputPin = 9; // Servo pin
int servo_pos = 0; // Current servo position
int servo_pos_a = 90; // Position destination a
int servo_pos_b = 174; // Position destination b
int servo_state = 0; // 0 = position a, 1 = position b
Servo mrservo; // create servo object to control the servo
pinMode(inputPin, INPUT); // Push Button
pinMode(ledPin, OUTPUT); // LED
mrservo.attach(outputPin); // attaches the servo on pin 9 to the servo object
Serial.println(“Starting…”);
btnVal = digitalRead(inputPin);
if(btnVal == LOW) {
Serial.println(“Button: LOW”);
if(servo_state) {
Serial.println(“Position: a”);
Serial.println(“Position: b”);
if(btnVal == HIGH) {
Serial.println(“Button: HIGH”);
if(servo_state) {
// Move from position a to position b
if(servo_state == 0) {
Serial.print(servo_pos_a); Serial.print(" to “); Serial.println(servo_pos_b);
for(servo_pos = servo_pos_a; servo_pos < servo_pos_b; servo_pos += 3) {
mrservo.write(servo_pos);
digitalWrite(ledPin, HIGH);
delay(15); // waits 15ms for the servo to reach the position
servo_state = 1;
} else { // Move from position b to position a
Serial.print(servo_pos_b); Serial.print(” to "); Serial.println(servo_pos_a);
for(servo_pos = servo_pos_b; servo_pos >= servo_pos_a ; servo_pos -= 3) {
digitalWrite(ledPin, LOW);
delay(15);
servo_state = 0;
// Separate each cycle’s output
Serial.println(); Serial.println();
delay(250);
First you need to determine how you are going to power the two servos. How are you presently powering the one servo? How did you plan on powering two servos? The Arduino board is designed to be able to supply only so much +5vdc current for external components and two servos is really asking for trouble.
Lefty
i didn't know that i would have problems. i guess i'll just have to attach a power source to the servo. i'll figure that out later. right now i'm just interested in solving to codding first. i like to figure one thing out before i try to figure out the next problem.
As you wish. However I would ask you how will you know if your software is 'solved' without first having the ablity to power up two servos properly and be able to run the sketch to see if it indeeds works correctly?
Lefty
i'll connect them one at a time. if they work when connected one at a time i'm going to assume that the codding works.
