As a learning exercise, I took the example programs of Blink and Fade and tried to combine them.
They both work as I can comment out either part and the other will work.
However when I combine them, only the blink works and I cannot see why.
Here is my kludge.
Thanks
int led = 9; // the PWM pin the LED is attached to
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
int i = 0;
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
// The Fade section
// set the brightness of pin 9:
// change the brightness for next time through the loop:
for (i = 0; i <= 255; i++);
analogWrite(led, brightness);
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255)
fadeAmount = -fadeAmount;
// wait for 30 milliseconds to see the dimming effect
delay(30);
// and the Blink section
for (i = 0; i < 255; i+5)
analogWrite(led, 255); // turn the LED on (HIGH is the voltage level)
delay(300); // wait for a second
analogWrite(led, 0); // turn the LED off by making the voltage LOW
Maybe your eye simply isn't fast enough.
You need to move the delay(30); inside of the for loops, otherwise the loops execute too fast for you to see, as hinted at by AWOL.
Also, take a closer look at the top two for loops - they are not error free.
Thank you all for the help though,,,,
Arduarn, I moved the delay(30) into both of the loops and no change.
Plus I dont see any errors in the code and it compiled with no errors.
I dont think that my vision is the issue as when I comment out certain sections, the other section works perfectly and I can see the fade and blink.
Still a mystery.
Say, I wonder if there is some reset that I need to do/push between each version of these kludges ?
Is there a reset button that says " Clear memory and start over ? "
Hmmm
Fade only....
int i = 0;
// The Fade section
delay(30);
delay(30);
Blink only,,,,,
int i = 0;
// The Fade section
/*for (i = 0; i <= 255; i++);
delay(30);
delay(30);
Well, I saw something that didnt look right so I changed it a bit and it still works the same..
This code..
Changed to this....
for (i = 0; i < 5; i++ )
// Wot? No alalogWrite() ?
fadeAmount = -fadeAmount; // 5 = -5, -5 = 5, 5 = -5...
And there may be more mistakes...
hextejas:
I dont think that my vision is the issue as ...
Thank you again Arduarn, you da man !
I am surprised that the error in the syntax of the if command was not caught by the compiler.
I have a lot to learn.
anyhow, I took the erroneous ;;; out and it works better now, I still have stuff to try and fix.
This code came straight from the "Fade" example. I put the "for" around it.
if (brightness <= 0 || brightness >= 255) {
delay(30);
And I dont understand your comment
Probably because there is no syntax error.
I think they were noting the absence of an analogWrite
Yeah, but once you modify it you own it.
AWOL:
I think he was noting the absence of an analogWrite
That and the fact that fadeAmount = -fadeAmount may make perfect sense in the fade example, but makes much less sense with the explicit for loops as shown.
