Trying to build a simple library.
I think I finally got the .h and .cpp files correct.
At least the Arduino IDE is not complaining about them anymore.
The IDE is complaining that the two functions in the library are not in scope.
sketch_Check_for_Prime_Number_v2:10: error: 'refresh_Screen' was not declared in this scope
sketch_Check_for_Prime_Number_v2:13: error: 'getChars' was not declared in this scope
//sketch_Check_for_Prime_Number_v2 -- not accepting all input
#include <stdio.h>
#include <Barry.h>
unsigned long int value; unsigned long int n; unsigned long int c = 2;
char s = 's';
refresh_Screen();
Serial.println("Enter a number to check if it is a prime\n");
char v = 'v';
getChars();
n = value;
if (value < 2) {
Serial.print("Not a candidate."); return;
for ( c = 2 ; c <= n - 1 ; c++ )
if (n % c == 0)
Serial.println(String(n) + " is not a prime."); break;
if ( c == n ) Serial.println(String(n) + " is a prime.");
void loop() {}
.h file
Barry.h - Library of general routines.
Created by Barry Block, July 22, 2016.
Released into the public domain for all to ignore.
#ifndef Barry_h
#define Barry_h
#include "Arduino.h"
class Barry
public:
Barry();
~Barry();
void refresh_Screen(char);
char s;
void getChars(char);
unsigned int long digits; unsigned int long value = 0; char k;
#endif
.cpp file
Barry.cpp - Library of general routines.
#include "Barry.h"
void Barry::refresh_Screen(char s)
Serial.write(27); // ESC
Serial.write("[2J"); // clear screen
Serial.write("[H"); // cursor to home
if (s == 's')
Serial.write("[3J"); // clear scrollback
void Barry::getChars(char k)
unsigned long int digits; unsigned long int value = 0; char keypress;
do
digits = Serial.available();
} while (digits < 1); // wait till a key is pressed. 1 == a key press
if (k == 'k')
keypress = Serial.read(); keypress = tolower(keypress);
do // collect the value if any
} while (digits == -1); // -1 is returned until a key is pressed
value = Serial.parseInt();
You declare a default constructor and a destructor, but do not provide a definition for them in the cpp file. Since you don't declare any other constructors and don't need any special behavior from your default, omit the declaration. The compiler will automatically generate a default constructor that initializes all member variables to their default value. For they integral types in your Barry class, they will all be 0;
Because you do not have any pointers or dynamic storage as class members, you do not need to define a custom destructor either. Omit it.
If you do not declare any contructors, the compiler will create basic versions of a default constructor, copy constructor, copy-assignment operator, and destructor.
refresh_Screen();
getChars();
refresh_Screen and getChars are member functions of the Barry class. It must be used by an object of type Barry. Ahraf's explanation above seems quite off, but the solution in the post is correct. Make those changes.
This makes no sense to me. I've played around with it but no success.
[pre][code]Berry barry = Barry();
... your code continue
[/code]
Using Barry.GetChars(); and Barry.refresh_Screen();
result in the errors:
sketch_Check_for_Prime_Number_v2:11: error: expected unqualified-id before '.' token
Barry.refresh_Screen('s');
sketch_Check_for_Prime_Number_v2:14: error: expected unqualified-id before '.' token
Barry.getChars(' ');
flat5:
[/code]
You're are only confusing me. I do not understand why a lower case barry is approprate or needed..
Did you look at the first post? Can you show me exactly what should be changed/added and where?
Please!
You must declare an instance of your class. It doesn't matter what you call it. I used barry for the instance name. Below I use myInstance as the instance name.
Barry myInstance; // this is the instance name
char ch = 'a';
myInstance.getChars(ch);
#ifndef Barry_h
#define Barry_h
class Barry
public:
char s;
#endif
Barry.cpp. This didn't change.
#include "Barry.h"
if (s == 's')
do
if (k == 'k')
The sketch.ino. Whatever you want to call it.
#include <stdio.h>
#include <Barry.h>
Barry barry;
char ch;
char s = 's';
barry.refresh_Screen(ch);
char v = 'v';
barry.getChars(ch);
n = value;
if (value < 2) {
if (n % c == 0)
void loop() {}
#include <stdio.h>
#include <Barry.h>
Barry barry;
char ch = 's';
//char s = 's';
char k = 'v';
barry.getChars(k);
n = value;
and I restarted the IDE and told it to include the lib...which it did.
But you gave me an idea.
I saved the .ino and told the IDE to "fix encoding and reload".
Errors went bye bye
Now I'll test and see what happens.
Thank you, Tim, for your patience and help!
I'll be thinking about this now that it works (I hope).
Well all the numbers I input are rejected. I can probably handle that.
Rejection is normal for me
I'll see what is happening with the variables. Probably use a few print statements to see what is taking place.
Thank you again, all of you!
