Hi everyone, i'm an italian software developer (objective-c, java, php), just started playing with arduino a week ago. I want to build a DHCP library for the new arduino release, at this moment i was able to send the DHCPDISCOVER packet well composed, and the dhcp server reply with a packet, but i can't receive that packet with the UDP library in arduino. Probably i miss something, are here someone able with udp and dhcp and want to collaborate in this library? thanks ;)
Have you searched for UDP and DHCP libraries allready (just to see how others did it?) e.g. http://bitbucket.org/bjoern/arduino_osc/src/tip/libraries/Ethernet/ http://blog.jordanterrell.com/post/Arduino-DHCP-Library-Version-04.aspx (google Arduino DHCP libraries)
yes i see other libraries, but they’re based on old version of ethernet library.
I do some progress, but don’t understand why, when serial monitor is opened, program does not receive the udp, as i close the serial monitor popup the led light up.
see the sketch attached, any help is approached (it’s a study sketch, so don’t take care by comments :-[ )
#include <SPI.h>
#include <Ethernet.h>
#include <Udp.h>
#define DEBUG
/* DHCP state machine. */
#define STATE_DHCP_START 0
#define STATE_DHCP_DISCOVER 1
#define STATE_DHCP_REQUEST 2
#define STATE_DHCP_LEASED 3
#define STATE_DHCP_REREQUEST 4
#define STATE_DHCP_RELEASE 5
#define DHCP_FLAGSBROADCAST 0x8000
/* UDP port numbers for DHCP */
#define DHCP_SERVER_PORT 67
#define DHCP_CLIENT_PORT 68
/* DHCP message OP code */
#define DHCP_BOOTREQUEST 1
#define DHCP_BOOTREPLY 2
/* DHCP message type */
#define DHCP_DISCOVER 1
#define DHCP_OFFER 2
#define DHCP_REQUEST 3
#define DHCP_DECLINE 4
#define DHCP_ACK 5
#define DHCP_NAK 6
#define DHCP_RELEASE 7
#define DHCP_INFORM 8
#define DHCP_HTYPE10MB 1
#define DHCP_HTYPE100MB 2
#define DHCP_HLENETHERNET 6
#define DHCP_HOPS 0
#define DHCP_SECS 0
#define dhcpSIZE 240
#define zap(x) if(x){free(x); x=0;}
* @brief for the DHCP message
typedef struct RIP_MSG{
byte op;
byte htype;
byte hlen;
byte hops;
unsigned long xid;
unsigned int secs;
unsigned int flags;
byte ciaddr[4];
byte yiaddr[4];
byte siaddr[4];
byte giaddr[4];
byte chaddr[16];
byte sname[64];
byte file[128];
byte magic[4];
byte OPT[];
* @brief DHCP option and value (cf. RFC1533)
enum{
DhcpOptionPadding = 0,
DhcpOptionSubnetMask = 1,
DhcpOptionRoutersOnSubnet = 3,
DhcpOptionDNS = 6,
DhcpOptionHostName = 12,
DhcpOptionDomainName = 15,
DhcpOptionRequestedIPaddr = 50,
DhcpOptionIPAddrLeaseTime = 51,
DhcpOptionOptionOverload = 52,
DhcpOptionMessageType = 53,
DhcpOptionServerIdentifier = 54,
DhcpOptionParamRequest = 55,
DhcpOptionMsg = 56,
DhcpOptionMaxMsgSize = 57,
DhcpOptionT1value = 58,
DhcpOptionT2value = 59,
DhcpOptionClassIdentifier = 60,
DhcpOptionClientIdentifier = 61,
DhcpOptionEnd = 255
byte mac[] = { 0xDE, 0xAF, 0xAE, 0xDF, 0xFE, 0xED };
byte ip[] = { 0,0,0,0 };
unsigned int dhcp_state;
unsigned long startTime;
unsigned long lastTime;
unsigned long _dhcpTransactionId = 123456; /* todo */
byte broadcastIp[] = { 255,255,255,255 };
byte dhcpServerIp[4];
// buffers for receiving and sending data
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet,
// start the Ethernet and UDP:
Ethernet.begin(mac,ip);
Udp.begin(DHCP_CLIENT_PORT);
startTime = millis();
lastTime = startTime;
dhcp_state = STATE_DHCP_START;
pinMode(9, OUTPUT);
digitalWrite(9, LOW);
if(dhcp_state == STATE_DHCP_START) {
#ifdef DEBUG
Serial.println("STATE_DHCP_START");
#endif
RIP_MSG *packet = (RIP_MSG *)malloc(dhcpSIZE +4 * sizeof(byte *));
packet->op = DHCP_BOOTREQUEST;
packet->htype = DHCP_HTYPE10MB;
packet->hlen = DHCP_HLENETHERNET;
packet->hops = DHCP_HOPS;
packet->xid = dhcp_swapl(_dhcpTransactionId);
packet->secs = 0;
packet->flags = dhcp_swaps(DHCP_FLAGSBROADCAST);
memset(packet->ciaddr, 0, 4);
memset(packet->yiaddr, 0, 4);
memset(packet->siaddr, 0, 4);
memset(packet->giaddr, 0, 4);
memset(packet->sname, 0, 64);
memset(packet->file, 0, 128);
memcpy(packet->chaddr, mac, sizeof(mac));
packet->magic[0] = 99;
packet->magic[1] = 130;
packet->magic[2] = 83;
packet->magic[3] = 99;
unsigned int ptr = 0;
// OPTION: message type
packet->OPT[ptr] = DhcpOptionMessageType;
ptr += 1;
packet->OPT[ptr] = 1;
ptr += 1;
packet->OPT[ptr] = 1; //DhcpMessageDiscover
ptr += 1;
packet->OPT[ptr] = DhcpOptionEnd;
ptr += 1;
Udp.sendPacket((byte *)packet,dhcpSIZE +4,broadcastIp,DHCP_SERVER_PORT);
#ifdef DEBUG
Serial.println("STATE_DHCP_DISCOVER");
Serial.print("send pack size: ");
Serial.println(sizeof(*packet));
#endif
dhcp_state = STATE_DHCP_DISCOVER;
zap(packet);
if(Udp.available()) {
// Get packet size and allocate memory
int packetSize = Udp.available()-8;
RIP_MSG *packet = (RIP_MSG *)malloc(packetSize * sizeof(byte *));
Udp.readPacket((byte *)packet,packetSize);
// Find real size and make copy of incoming options
// Attempt to handle missing 'DhcpOptionEnd' - corrupted line?
int optLoc = 0;
while(packet->OPT[optLoc] != DhcpOptionEnd && optLoc < packetSize-dhcpSIZE){
optLoc = 2+optLoc+packet->OPT[optLoc+1];
int optSize = optLoc;
byte *options = (byte *)malloc(optSize * sizeof(byte *));
memcpy( options , packet->OPT , optSize);
digitalWrite(9, HIGH);
#ifdef DEBUG
Serial.print("Packet size ");
Serial.println(packetSize, DEC);
Serial.print("Options size ");
Serial.println(optSize, DEC);
Serial.println("Fetched");
for(int i = 0;i < (optSize);i++){
Serial.print(options[i], DEC);
Serial.print(" ");
#endif
#ifdef DEBUG
if( millis()-lastTime > 1000 ){
Serial.print(".");
lastTime = millis();
#endif
uint16_t dhcp_swaps(uint16_t i) {
uint16_t ret=0;
ret = (i & 0xFF) << 8;
ret |= ((i >> 8)& 0xFF);
return ret;
uint32_t dhcp_swapl(uint32_t l) {
uint32_t ret=0;
ret = (l & 0xFF) << 24;
ret |= ((l >> 8) & 0xFF) << 16;
ret |= ((l >> 16) & 0xFF) << 8;
ret |= ((l >> 24) & 0xFF);
return ret;
This might give you some ideas:
http://www.musically.me.uk/DHCP_Web_Server_12.pde
it's the most recent version of my attempt to get a DHCP server.
More details here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1273689407
Check the last few entries :)
