trying to burn bootloader
Unfortunately, I brought a Atmega 328p-pu without a bootloader. Now I am using my Uno as ISP and having external crystal connected to Atmega just as the wiring in "From Arduino to a Microcontroller on a Breadboard' make it.
I found that 16M crystal didn't oscillate. Does that mean I had messed up with the fuses(CKSEL[3:0])?
Thanks in advance!
Error Message
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Uno"
D:\Arduino\hardware\tools\avr/bin/avrdude -CD:\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM7 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "D:\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
Check out this url from Mr. Gammon. Add the capacitors .1uF according to the attached .jpg.
Chuan:
this check.
The error means exactly what it means. Probably something wring in your HW setup. If you suspect the crystal you have to replace it.
ATmega uses internal clock by default but at first bootloading attempt the fuses go first and oscillator is changed to external. If there is missing clock signal the chip cannot start.
You can also use Arduino as ISP as clock generator on UNO's pin 9 adding short code at the end of setup() function
setup() {
	pinMode(9,     OUTPUT);
	OCR1A  = 0;
	ICR1   = 1;
	TCCR1A = _BV(WGM11) | _BV(COM1A1);
	TCCR1B = _BV(WGM13) | _BV(WGM12) |_BV(CS10);
					// fast PWM; ICR1 ~ TOP; OCR1A updade ~ BOTTOM; TOV1 flag set ~TOP;
					// clk/1 ~ no prescaling clock;
					// clear OC1A on Compare Match, set OC1A at bottom
Just connect pin 9 to XTAL1 pin on ATmega328P.
Budvar10, thanks a lot! Now it works.
Cheers!
