Hey everyone!
What I'm trying to do is the following: I want to be able to parse a string, and then call the function associated with that string with arguments separated by a delimiter. I think I have this part done fine, except I can't call my function instance properly in Arduino.
#include <ArduinoSTL.h>
#include
#include
#include
#include
#include <EEPROM.h>
#define LED_PIN 4
#define LED_COUNT 12
#define MY_ROLE 0
//#define CALL_MEMBER_FN(object,ptrToMember) ((object).*(ptrToMember)) //This call doesn't work in Arduino#define X_ADDR 0
#define Y_ADDR 1
#define MY_ROLE 2Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
class CommandHandler{
typedef void (CommandHandler::*pfunc)(std::vector&);CommandHandler::CommandHandler(){
x = EEPROM.read(X_ADDR);
y = EEPROM.read(Y_ADDR);
role_id = MY_ROLE;
init_commands_with_args();
CommandHandler::CommandHandler(int x, int y, int role_id){
this->x = x;
this->y = y;
this->role_id = role_id;
public:
int x, y, role_id;
std::map<String, pfunc> commandsTable;
void set_red(){show_led_int(255,0,0);}
void set_green(){show_led_int(0,255,0);}
void set_blue(){show_led_int(0,0,255);}
void set_purple(){show_led_int(255, 0, 255);}
void set_yellow(){show_led_int(255, 255, 0);}
void set_cyan(){show_led_int(0,255,255);}
void set_white(){show_led_int(255,255,255);}
void set_none(){show_led_int(0,0,0);}void init_commands_with_args(){
commandsTable["a"] = &show_led;
//commandsTable["b"] = &blink_color;
//commandsTable["c"] = &theaterChase;
//commandsTable["d"] = &rainbow;
//commandsTable["e"] = &theaterChaseRainbow;
return;
}void handle_command(std::string input, std::string delimiter = "/"){
if (input.size() == 1){
switch(input[0]){
case 'R':
CommandHandler::set_red();
case 'B':
CommandHandler::set_blue();
case 'G':
CommandHandler::set_green();
case 'W':
CommandHandler::set_white();
case 'P':
CommandHandler::set_purple();
case 'C':
CommandHandler::set_cyan();
case 'Y':
CommandHandler::set_yellow();
case 'N':
CommandHandler::set_none();
else{
std::vector parses; // 10 maximum args
size_t pos = 0; size_t i = 0;
String token;
//std::string tokens = s.substr(0, s.find(delimiter));
while ((pos = input.find(delimiter)) != std::string::npos) {
token = String(input.substr(0, pos).c_str());
//std::cout << token << std::endl;
parses.push_back(token);
input.erase(0, pos + delimiter.length());
i++;
//Parses is now an array of strings.
pfunc cmd_func = commandsTable[parses[0]];
parses.erase(parses.begin());
((this).(*(this.cmd_func)))(parses); //This line fails no matter what I try to do. //Expected unqualified-id before '(' token
//I want to call the function of this instance that is in commandsTable, with arguments defined in the vector parses.
//The first element of the vector which is later erased is the function in commandsTable that is mapped
//Other elements are arguments in the string.
void show_led(std::vector & input){
int r = String(input[0].c_str()).toInt();
int b = String(input[1].c_str()).toInt();
int g = String(input[2].c_str()).toInt();
uint32_t mycolor = strip.Color(r, b, g);
strip.setPixelColor(0, mycolor);
strip.setPixelColor(1, mycolor);
strip.setPixelColor(2, mycolor);
strip.setPixelColor(3, mycolor);
strip.setPixelColor(4, mycolor);
strip.setPixelColor(5, mycolor);
strip.setPixelColor(6, mycolor);
strip.setPixelColor(7, mycolor);
strip.setPixelColor(8, mycolor);
strip.setPixelColor(9, mycolor);
strip.setPixelColor(10, mycolor);
strip.setPixelColor(11, mycolor);
strip.show();
The relevant snippet of this code is the following:
I'm having issues with calling this instance's function definition. I get the above error doing multiple / different types of syntaxes to support member to function pointers. What did I do wrong?
Thanks!
sketch_feb08a.ino (9.32 KB)
