Trying to change analog pins within this encoder code
Hi
I have been trying to adapt a piece of code to use other pins than the ones stated in the piece of code. at the moment analog pins 0 and 1 are used and working. the problem is the first three pins are being used for another piece of my project and this cannot be changed. Any advice on how to change the pins used for the encoder from A0 and A1 to A4 and A5 would be appreciated.
Thanks :slight_smile:
/* Rotary encoder read example */
#define ENC_A 14
#define ENC_B 15
#define ENC_PORT PINC
/* Setup encoder pins as inputs */
pinMode(ENC_A, INPUT);
digitalWrite(ENC_A, HIGH);
pinMode(ENC_B, INPUT);
digitalWrite(ENC_B, HIGH);
Serial.begin (115200);
Serial.println(‚ÄúStart‚ÄĚ);
static uint8_t counter = 0; //this variable will be changed by encoder input
int8_t tmpdata;
tmpdata = read_encoder();
if( tmpdata ) {
Serial.print("Counter value: ");
Serial.println(counter, DEC);
counter += tmpdata;
/* returns change in encoder state (-1,0,1) */
int8_t read_encoder()
static int8_t enc_states = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0};
static uint8_t old_AB = 0;
old_AB <<= 2; //remember previous state
old_AB |= ( ENC_PORT & 0x03 ); //add current state
return ( enc_states[( old_AB & 0x0f )]);
Here
#define ENC_A 14
#define ENC_B 15
and   old_AB |= ( ENC_PORT & 0x03 );  //add current state
Please use code tags when posting code.
I managed to get it working with the following code :slight_smile:
#define ENC_A 8
#define ENC_B 9
#define ENC_PORT PINB
  Serial.println("Start");
 int8_t tmpdata;
  if( tmpdata ) {
    counter += tmpdata;
  static int8_t enc_states[] = {0,-1,1,0,1,0,0,-1,-1,0,0,1,0,1,-1,0};
I thought you wanted it on A4 and A5 (PORTC) ?
I only really needed to free up A0 A1 and A2 as these were already in use with another part of the project.
