Trying to code a pump using an input from a moisture sensor
Hi there,
I'm in the middle of doing a project which is an automatic watering system for a plant pot. I've got all of the circuits sorted but now that I'm onto the coding, im sort of confused...
So with the moisture sensor I've calibrated it so I know at what value the plant needs watering, at what value it is at maximum dryness and maximum wetness and at what value it should stop watering again (so that the soil isn't waterlogged).
The max dryness value is around 750 and wetness at 150.
The way I want it to work is for the code to keep checking wether the dryness gets to a value bigger than 400. If it is then I want it to start watering until it's reading a value of 200 then to stop watering and repeat the cycle.
I'm not sure how to code this but I'm sure there's a simple way of doing it.
Thanks in advance for your help!
Ali
// here's where you setup the pin modes for your sensor, other inputs and outputs etc.
if (sensorValue() >= 400) wateringOff();
if (sensorValue() <= 200) wateringOn();
int sensorValue() {
int x = 0;
// where you read the pin value into x
return x;
void wateringOff() {
// where you do what you need to turn off the water
void wateringOn() {
// where you do what you need to turn on the water
Perehama:
// here’s where you setup the pin modes for your sensor, other inputs and outputs etc.
int sensorValue() {
int x = 0;
return x;
void wateringOn() {
int pump = 8;
int LED = 7;
pinMode(pump, OUTPUT);
pinMode(LED, OUTPUT);
  int sensorValue = analogRead(A0);
if (sensorValue() <= 200) wateringOn();*****************************
digitalWrite(pump, LOW)
digitalWrite(LED, LOW);
void wateringOn() {
digitalWrite(pump, HIGH);
digitalWrite(LED, HIGH);
Using this code, I get an error message saying “Expected unqualified-id before ‘if’” (I’ve put stars on the highlighted line. :confused:
You can not have function calls outside of a function. Pay attention to where loop() ends. You fat-fingered the code that perehama posted.
CrazyPharaoh:
If you have nothing but analogRead() as your condition, then your loop() should be as follows:
if (analogRead(A0) >= 400) wateringOff();
if (analogRead(A0) <= 200) wateringOn();
