// MH-Z19B CO2 Sensor Serial Communication Example
#include "PMS.h"
PMS pms(Serial1);
PMS::DATA data;
// Define the serial port for MH-Z19B sensor (Serial3 on Arduino Mega)
#define MHZ19B_SERIAL Serial2
// Define the serial port for Bluetooth (Serial2 on Arduino Mega)
#define BLUETOOTH_SERIAL Serial3
// Define the baud rate for MH-Z19B sensor
#define MHZ19B_BAUDRATE 9600
// Define the command to read CO2 concentration
uint8_t MHZ19B_CMD_READ_CO2[] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
// Define the zero point CO2 concentration (e.g., typical outdoor level)
#define ZERO_POINT_CO2 400 // ppm
// Initialize Serial Monitor for debugging
BLUETOOTH_SERIAL.begin(9600);
//pms5003
Serial1.begin(9600);
// Initialize MH-Z19B Serial Port
MHZ19B_SERIAL.begin(MHZ19B_BAUDRATE);
// Wait for the sensor to warm up
delay(2000);
// Perform zero point calibration
calibrateZeroPoint();
void co2();
void pm();
void co2(){
if (pms.read(data))
Serial.print("PM 1.0 (ug/m3): ");
Serial.println(data.PM_AE_UG_1_0);
BLUETOOTH_SERIAL.print(data.PM_AE_UG_1_0);
BLUETOOTH_SERIAL.print("ug/m3");
BLUETOOTH_SERIAL.print(",");
Serial.print("PM 2.5 (ug/m3): ");
Serial.println(data.PM_AE_UG_2_5);
BLUETOOTH_SERIAL.print(data.PM_AE_UG_2_5);
Serial.print("PM 10.0 (ug/m3): ");
Serial.println(data.PM_AE_UG_10_0);
BLUETOOTH_SERIAL.print(data.PM_AE_UG_10_0);
// Send command to MH-Z19B sensor to read CO2 concentration
MHZ19B_SERIAL.write(MHZ19B_CMD_READ_CO2, sizeof(MHZ19B_CMD_READ_CO2));
// Wait for sensor to respond (80 ms)
delay(80);
// Read response from the sensor
uint8_t response[9];
MHZ19B_SERIAL.readBytes(response, 9);
// Check if response is valid
if (response[0] == 0xFF && response[1] == 0x86) {
// Calculate CO2 concentration (high byte * 256 + low byte)
int co2 = response[2] * 256 + response[3];
// Print CO2 concentration to Bluetooth
Serial.print(co2);
Serial.println(" ppm");
BLUETOOTH_SERIAL.print(co2);
BLUETOOTH_SERIAL.print(" ppm");
BLUETOOTH_SERIAL.print(";");
// Print error if response is invalid to Bluetooth
Serial.println("Error: Invalid response from sensor");
// Delay before next reading
delay(5000); // Adjust delay time as needed
void pm(){
if (pms.read(data))
void calibrateZeroPoint() {
// Send command to MH-Z19B sensor to calibrate zero point
// The zero point command for MH-Z19B is: FF 01 87 00 00 00 00 00 78
uint8_t MHZ19B_CMD_CALIBRATE_ZERO_POINT[] = {0xFF, 0x01, 0x87, 0x00, 0x00, 0x00, 0x00, 0x00, 0x78};
MHZ19B_SERIAL.write(MHZ19B_CMD_CALIBRATE_ZERO_POINT, sizeof(MHZ19B_CMD_CALIBRATE_ZERO_POINT));
// Wait for calibration to complete
delay(3000); // Calibration takes approximately 3 seconds
Basically if i use each sensor alone, they work. But when i try to combine them, nothing appears on my serial monitor. I tried to define the co2 and pm code for each sensor then call it into the void loop() , but won t work.
Comments that don't match the statement are worse than no comments. This might indicate that the wiring does not match the code; note that we can't possibly know.
#include "PMS.h"
PMS pms(Serial1);
PMS::DATA data;
//pms5003
delay(2000);
void pm(){
if (pms.read(data))
void co2(){
if (pms.read(data))
delay(80);
Serial.print(co2);
pm();
co2();
I only get the co2 values.
I forgot to remove the comments. The hardware matches the software.
Pms5003 is on rx1, tx1 (rx-tx, tx-rx)
mh-z19b is on rx2, tx2 (same as above)
bt hc-05 is on rx3, tx3 (same as above)
#include "PMS.h"
PMS pms(Serial1);
PMS::DATA data;
//pms5003
delay(2000);
void pm(){
if (pms.read(data))
void co2(){
if (pms.read(data))
delay(80);
Serial.print(co2);
pm();
co2();
now i only get co2 values and sometimes and randomly ( once ) the pms :
18:11:49.312 -> PM 1.0 (ug/m3): 2
18:11:49.312 -> PM 2.5 (ug/m3): 2
18:11:49.374 -> PM 10.0 (ug/m3): 2
18:11:49.374 ->
18:11:49.406 -> 404 ppm
